Old 07-10-2012, 08:23 PM   #1
SF-FRS
Drives: 2013 Scion FRS
Alignment adjusted at 250 miles
I've noticed on day 1 my FR-S had a pull to the right. I finally decided to bring it in to the dealer for adjustment. Found out the toe was off in the front and rear right wheel.
SF-FRS is offline   Reply With Quote
Old 07-10-2012, 10:17 PM   #2
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Yikes! Do you suspect it was from the dealership or from the car loosening up? I guess we should all check too! Thanks for the heads-up
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 07-10-2012, 11:09 PM   #3
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
Mine seems true so far!
Rossman is offline   Reply With Quote
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 06:30 PM
Actual alignment specs from BRZ taosracer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 06-29-2012 09:33 AM
Alignment needed after lowering car? Lowellrenzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-16-2012 02:57 PM
Whiteline alignment products Nardi330 AUSTRALIA 4 06-16-2012 03:25 AM
is the alignment on the FRS/BRZ adjustable? neveronlinefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-05-2012 03:58 PM
