Old 10-28-2016, 09:15 PM   #1
Fartsicle
Drives: Fr-s trd
My 400+ Whp FRS daily log
Hey guys,
I went from supercharger to a jdl single scroll turbo. I'm making 412 rear wheel hp on ethanol.
All on a stock automatic transmission, and a stock rear axle
I've seen some interest in other threads on high horsepower builds with an automatic transmission. I'd figure I'd update this thread daily with any issues!
I'll post photos tomorrow if you'd like.
The wheel spin is crazy on pilot super sport tires, but manageable. Traction control does nothing at this point anymore either.
Today I drove 50 miles, red lined multiple times (first day I got it back with turbo) and so far no issues
Fartsicle is offline   Reply With Quote
Old 10-28-2016, 09:41 PM   #2
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Build thread?
Packofcrows is offline   Reply With Quote
Old 10-29-2016, 02:01 PM   #3
Fartsicle
Drives: Fr-s trd
Added photos!
Old 10-29-2016, 04:36 PM   #4
fguadamuz
Drives: 2013 BRZ Silver M/T
Any dyno sheet?
fguadamuz is offline   Reply With Quote
Old 10-29-2016, 05:24 PM   #5
Fartsicle
Drives: Fr-s trd
Here's my dyno sheet and a view of the car.
Old 10-30-2016, 07:23 PM   #6
WhiteBRZ4
Drives: 2015 Subaru BRZ Sport-Tech
i do not understand how your motor is handling that power jeeehz. my motor is pushing 280 whp and 220 lb/tq on a SC and im scared to go higher. Curious to see how your motor holds up!
WhiteBRZ4 is offline   Reply With Quote
Old 10-31-2016, 08:22 AM   #7
Fartsicle
Drives: Fr-s trd
I have a built motor now. I ran my stock motor on 300whp for 4-5 thousand miles just fine.
Old 10-31-2016, 09:43 AM   #8
Yoda
Drives: Crystal Black BRZ(Sophia)
Not sure if this is posted up somewhere. Can the auto trans hold more power than the mani?
Yoda is offline   Reply With Quote
Old 10-31-2016, 10:10 AM   #9
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Yes.
Old 10-31-2016, 10:27 AM   #10
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Car/engine bay looks good
On a side note have you had problems with those mishimoto lugs? I have the same ones and when i had a shop put on my new wheels and those lugs the tech said he was able to use the included tool for about half of the lugs and had to use a 19mm socket for the other half. I tested the included socket myself and it actually didn't fit half of the lugs.
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 10-31-2016, 09:30 PM   #11
Fartsicle
Drives: Fr-s trd
I didn't install the lugs myself, the performance shop did. I honestly don't like them. I'm putting the OEM ones back on tomorrow.
I had the CEL and slip indicator turn on solid.
P0300 - multiple cyclinder misfire
P0014 - camshift position
P000B - camshaft timing
The car is running completely fine. I'm assuming these have to do with the built motor. Any idea what's going on?
I'm taking it back to the performance shop tomorrow.
Also, the solid slip indicator means TCS is disable... correct?
Also, I understand CEL also lowers performance, is this true?
Old 11-01-2016, 12:27 PM   #12
sirsol66
Drives: 2013 FRS- Hot Lava
The P0014 and P000B was a common code with the early cars that had cam issues. I'm guessing its a built issue from whoever put your motor together? Have the shop check it.
sirsol66 is offline   Reply With Quote
Old 11-01-2016, 04:51 PM   #13
Fartsicle
Drives: Fr-s trd
Car has been dropped off. I'll update when I have more information.
Old 11-02-2016, 01:23 AM   #14
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
That is actually a very appealing torque curve.
Would you mind telling me the compression your engine is running now?
Cheers
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
18x8.75 For daily. DGM-BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 06-22-2016 06:28 PM
Do you Daily your FR-S? MisterSheep Scion FR-S / Toyota 86 GT86 General Forum 138 05-12-2016 06:37 PM
N_A's daily FRS N_A Member's Car Journals 5 08-13-2014 11:52 PM
My Daily Raven FR-S A/T Thehermdawg Member's Car Journals 0 05-17-2014 03:12 PM
Who dog's there car out on a daily? drift94 Scion FR-S / Toyota 86 GT86 General Forum 23 06-03-2013 10:40 PM
