Old 10-28-2016, 12:28 AM   #1
justinh77
justinh77's Avatar
Drives: pearl white scion frs 2014
New Throttle body is it worth the money?
So im new to the forums so i hope im posting in the right category.
i've bin modding my frs with bolt-ons starting from the intake and working my way down the exhaust. I have came across thread about the cusco throttle body and read the $1k is not worth it at all for the product which i fully agree.
BUT, the other day i came across the grams 72mm throttle body for 400$ and it apparently gives just below a 50% increase of airflow.
http://www.ft86speedfactory.com/gram...l#.WBLSWODx7IV
YAY or NAY?
i'd like to hear your opinions about it before i regret buying it ahaha. Thnx
justinh77 is offline   Reply With Quote
Old 10-28-2016, 01:06 AM   #2
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
Short answer: No.
Long answer: Nooooooooooooooooooo.
menikmati is offline   Reply With Quote
The Following 13 Users Say Thank You to menikmati For This Useful Post:
Bramick (10-28-2016), Calum (10-28-2016), cdrazic93 (11-08-2016), go_a_way1 (11-08-2016), gramicci101 (11-08-2016), JD001 (11-08-2016), JDM4E (11-07-2016), JohnJuan (11-08-2016), Muaddib (11-17-2017), Strife26 (12-08-2017), Toyarzee (11-08-2016), wparsons (11-08-2016)
Old 10-28-2016, 01:10 AM   #3
steve99
Not seen any dyno results that indicate significant gains on NA or boosted cars with bigger throttle bodies.
The throttle body may be capable of flowing more air but the engine , intake and exhaust would need to all flow better to take advantage of the throttle body flow.
People running 15 psi or more boost on stock throttle body.
On an NA car the things that will get you most of the gains for least outlay are tune, catless header, E85 fuel and a drop in filter in stock intake. After that you will spend heaps for little more on an NA car, save your $$$$ for fi or another car after those mods.
see Basic Bolt on Mods Guide link below
Irace86 (10-28-2016)
Old 10-28-2016, 02:03 AM   #4
Irace86
Drives: BRZ + Ducati M796
what he said... except I would say just core the stock header for best bang for buck outcome. Anyone dropping big bucks on a header is wasting money, but that's just my opinion.
Irace86 is offline   Reply With Quote
The Following User Says Thank You to Irace86 For This Useful Post:
guybo (11-24-2017)
Old 11-07-2016, 01:08 PM   #5
TilesMeague
TilesMeague's Avatar
Drives: 2013 SSM BRZ
So it seems like a big focus in this thread is bang for your buck performance wise, but I really get a kick out of the sounds too. The Dinan throttle bodies on my dads e46 sound amazing and I'm wondering if the same would be expected for an 86?
Drop several gears and become slightly further away
TilesMeague is offline   Reply With Quote
Old 11-07-2016, 08:15 PM   #6
Hawk77FT
Drives: GTS 86
Anyone dropping big bucks on a S#it header is wasting money, but that's just my opinion.
There, i fixed it for you. There are couple of headers out there that outperformed the stock header by miles. If your opinion would have been somewhat true, we would see no gains whatsoever from changing the header on NA or even FI (SC in particular). Your statement however is very very true if you are talking about intakes where people drop serious coin on something that will make fa difference when compared to a drop in filter.
Hawk77FT is offline   Reply With Quote
The Following User Says Thank You to Hawk77FT For This Useful Post:
Old 11-08-2016, 02:21 AM   #7
Irace86
I think a guy like me, who owns a welder, can weld in a straight pipe after decoring the cat for under ten bucks. Compare that to a header that is $500-1500, and the cost to hp gain is in my favor.
chaoskaze (07-22-2018)
Old 11-08-2016, 02:51 AM   #8
Hawk77FT
Drives: GTS 86
I guess all aftermarket industry, race teams got it all wrong man! Damn, so it's just cat Cs no cat these days! And save money. Cheers man
Sent from my HTC_0P6B using Tapatalk
Old 11-08-2016, 09:21 AM   #9
D_Thissen
D_Thissen's Avatar
IIRC someone had there car dyno'd with the bigger tb and picked up around 10-12whp on the top end. They also were boosted (C38 blower I think) with header, full exhaust running e70. 320whp seems to stick out in my head.
Old 11-08-2016, 01:36 PM   #10
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
This modification is quite popular in Japan among specific tuners (e.g. ASM). It's not only about top end gains, but most important about torque gains in the low-mid rpm range. In Western countries it is not very common. I guess the cost will be quite high, because tuner/manufacturer will need to order a new throttle body from the factory. The OEM throttle body is expensive. Additionally, it requires boring the part which is not an easy task. Overall, it is a modification with a high cost and a potential of very low profits ...
Old 11-08-2016, 01:53 PM   #11
gramicci101
Off Topic
If you've already done FI and full exhaust and intake and flex fuel and tune and everything else short of modifying engine internals, and you know the throttle body is actually restricting your airflow, then yes. At that point, it becomes beneficial. It's already larger than the engine needs, so you have a lot of modifying to do before you max it out.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
toyubie (07-22-2018), wparsons (11-08-2016)
Old 11-08-2016, 02:04 PM   #12
This^
There is no magic bolt on that does miracles all on it's own. Each part has to be considered in relation to the whole and not looked at as, this part = this gain. Not impossible to think that a larger TB without supporting parts and a tune could actually decrease performance.
Reading manufacture's claims of "this part will do this for you" can be a bit of a trap so the OP did the right thing in researching.
Old 11-08-2016, 03:51 PM   #13
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Personally, I asked a respectable manufacturer and they told me that a bigger throttle body works even with everything else stock. Additionally, it will give better gains with a tune (i.e., MAF re-program) and even better gains with a free-flow exhaust. All the previous changes are additive and help each other.
In fact, the story behind the Gazoo racing intake started when some shops played with independent throttle bodies. The results were quite successful that Toyota started to engineer them, including additional changes on the rest of the intake and multiple intake runners.
I guess cost limitations and emission standards don't let the manufacturer to include these changes in the base car.
Old 11-08-2016, 04:50 PM   #14
wparsons
wparsons's Avatar
Were they talking about cars in general, or about these cars specifically? Some cars come with small (for engine size) TB's and can make huge gains. Our TB's are actually pretty huge for a 2L engine, and are bigger than what lots of people upgrade to on other 2L engines. A bigger TB might *feel* faster at part throttle because for 15* of throttle opening lets in more air, but that doesn't mean it's going to make a single hp more at WOT.
That looks like dual runners, not ITB's... the idea with dual runners (or variable runner length) is to run longer runners at low RPM to help power in that range and then the shorter runners at high RPM for more power.
Hardly a new idea, engines back as far as the early 90's (or maybe earlier) had manifolds like that.
flickr
bolt ons, mods, throttle, throttle body
FI, Worth the money or not? HGaudio Forced Induction 27 03-18-2015 08:33 PM
WTB FRS/BRZ Throttle Body Tboxer Want-To-Buy Requests 3 12-01-2014 12:13 PM
Are these cars worth the money? gt8613 BRZ First-Gen (2012+) — General Topics 80 10-12-2014 06:06 PM
Pulley systems, what are they good for and worth the money? K-NoMs Engine, Exhaust, Transmission 44 09-06-2014 02:01 AM
