Old 10-25-2016, 10:55 AM   #1
MatthewFRS
Is it possible to make Plastidip Permanent?
So I've heard that people put a clear coat over plastidip to make it permanent, and I wanted to know how if it's true.. Does anyone know if this works, or have an alternative way?
MatthewFRS is offline   Reply With Quote
Old 10-25-2016, 11:01 AM   #2
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
No. Plastidip is made to be peeled off so it doesn't matter what you actually put on top of it.
That being said,The more coats you use,the better it holds up over time. I dipped a white spoiler black no clear coat,and it's held up over the entire summer without any signs of distress. Waiting to see how it holds up over the winter though.
If you are doing wheels,I would say that the only way to possibly make them hold up better than normal is to primer the wheels first,then coat the shit out of each tire,then add your clear finish.Even then,I'm 99.999% positive that it can be removed without much trouble.
Th3rdSun is offline   Reply With Quote
Old 10-25-2016, 11:11 AM   #3
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
why not just use paint instead of plastidip?
shiumai is offline   Reply With Quote
Old 10-25-2016, 11:11 AM   #4
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I used plastidip to black out a chrome grille on my old beater forester. I used automotive clear over it in several coats. It does add a shine that straight plastidip does not have originally.
Could not peel it off once the clear had cured. Looked exactly the same when I got rid of the car as well.
I'm guessing if you sat and picked at it, or cut the clear, or started it where maybe you didn't have great overlap on the backside or something you could get it to peel.
Old 10-25-2016, 11:12 AM   #5
i heart ricers
Drives: g37 - 370z
nope
i heart ricers is offline   Reply With Quote
Old 10-25-2016, 11:12 AM   #6
Summerwolf
Panda Trueno
Summerwolf's Avatar
Good question! The plastidip coats with no original preparation, and it is cheap. In my instance I blacked out a grille, made it (at least somewhat) permanent, for around 20 bucks total and it made the beater look slightly better.
Old 10-25-2016, 11:19 AM   #7
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Do you have any experience with plastidip on high traffic-interior pieces. Say like a door sill?
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 10-25-2016, 11:25 AM   #8
Summerwolf
Panda Trueno
Summerwolf's Avatar
Not one clue, I never wanted to use plastidip in any way shape or form until that grille piece. Even then it was a stretch.
Old 10-25-2016, 11:27 AM   #9
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Old 10-25-2016, 01:06 PM   #10
Th3rdSun
I have a few pieces done. I would say you probably need to use a clear or matte finish to make it last.
I dipped my chrome Raceseng Ashiko shift knob. Had to redo it twice because I didn't put a finishing coat on after the red either time.On the third attempt,I put about three coats of matte finish after about seven coats of red(actually used the Duplicolor brand) and it's held up marvelously since mid/late July.
Old 10-25-2016, 01:10 PM   #11
i heart ricers
Drives: g37 - 370z
try spray glue then plasti dip on top
Old 10-25-2016, 01:47 PM   #12
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
That's just the kind of review I was looking for. My buddy and I are looking for a solution on a Civic side project that we're working on. Toying around with different ideas for some door sills and other interior bits.
Old 10-25-2016, 02:34 PM   #13
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
It's my understanding that a clear coat on top of Plastidip is to make it easier to clean. Dirt then less likely to adhere to it's surface.
And the more coats of Plastidip used, makes it easier to peel off when you want to remove it...thicker paint is easier to remove than thin paint.
Plastidip enhancers on this page:
https://plastidip.com/our-products/p...hy-dull-finish
ToySub1946 is offline   Reply With Quote
Old 10-25-2016, 02:50 PM   #14
MatthewFRS
I'd like to have something removable incase I sell the wheels.
Permanent Traction Override Switch DarrenDriven DIY (Do-It-Yourself) Guides 197 07-14-2020 11:03 AM
Semi-Permanent Tire Shine Group Buy Hamza7 CANADA 0 06-29-2014 04:36 PM
Honda S2000: CeramicPro 9H - Permanent Coating goat_cheese Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-07-2014 05:09 PM
Permanent Optimum opti-coat 2.0 ?? Ericfrs Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 09-04-2012 02:11 AM
