Old 10-17-2016, 01:05 PM   #1
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Backup camera install notes...
Installed my backup camera over the weekend and have some comments/tips that may help others...
1) I bought the harness from autoharnesshouse.com, and Brian was great. They really stand behind their product and have a "do the right thing for the customer" attitude. I had a slight issue with one connector and not only did Brian make a suggestion that cleared up the problem, he offered to send a replacement unit if I had any difficulty. Great customer service.
2) I used a 36 inch zip-tie as a wire snake and it was great. I did NOT have to take out the rear seat nor the rear seat panel trim.
3) I used the following 5 degree bevel washers to alter the camera angle slightly and they are perfect for the rydeen duo camera. 6GA10 Square Washer, M8, Pk10 link to ebay auction.
4) I spent far too much time debating where to mount the camera... I ended up NOT choosing the middle, since the 2016 cars mount it to the left side and I wanted to appear stock. Having lived with it for 3 days, I can honestly say there are no drawbacks to mounting it in the factory position - you have to REALLY try to tell that it is not centered. The camera is sooo wide angle/practically fish-eyed that the 8 inch difference from centered is meaningless. Upon further inspection, it appears that there is a BENEFIT to the stock location... the center of the trunk garnish is slightly angled in the WRONG direction!
A backup camera is a GREAT addition to this car!!!
P.S. I only used two washers (one to tilt the camera, the second reversed to compensate for the angle of threads and the retaining nut), so PM me with an address and I can help out the next 4 people with rydeen duos who want to try this!. Note that the hole in the washer is 1/2 inch diameter so these will NOT work with the backup cameras that require a larger hole to mount.
Last edited by nextcar; 10-19-2016 at 12:58 AM. Reason: Added note about diameter of washer hole & item #4
nextcar is offline   Reply With Quote
The Following 3 Users Say Thank You to nextcar For This Useful Post:
chaoskaze (10-22-2016), RickyBobby (10-17-2016), tobin (10-17-2016)
Old 10-22-2016, 12:58 PM   #2
Dynamikeee
Anyway you have pictures of where you mounted the camera?
Dynamikeee is offline   Reply With Quote
Old 10-22-2016, 05:17 PM   #3
nextcar
Here is where I mounted the camera... Just like a 2016!
Old 10-22-2016, 05:19 PM   #4
nextcar
Picture of display...
Using the 5 degree washers, here is what the display looks like. Note the edge of the bumper is barely visible at the bottom of the screen and the backup lines are almost exactly at 1 foot increments.
Old 10-31-2016, 09:05 PM   #5
FrostyPaws
FrostyPaws's Avatar
Drives: Blue Monogram FRS
Nice job man. Going to do this very soon.
FrostyPaws is offline   Reply With Quote
Old 10-31-2016, 10:03 PM   #6
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
Nice job. Got mine here:
http://www.emeraldintegrations.com/c...ra-system.html
Great quality, and you are correct sir - I will never be without one again. Pair this with DD LED reverse bulbs and the tails as turns so your signals can be set up as led reverse also, and you'll see nothing but daylight behind you on pitch black nights when you shift into R.
geezerbrzeezer is offline   Reply With Quote
Old 11-27-2017, 01:58 PM   #7
TheStig85
Drives: 2013 Subaru BRZ
How difficult was the install? Or straight plug&play? Electronics/Wiring and I don't mix :x
TheStig85 is offline   Reply With Quote
Old 11-27-2017, 02:31 PM   #8
ermax
ermax's Avatar
Not plug in play and you can get a camera just like this one on Amazon for much less.
Backup camera install around Orlando Florida? VeganGirl Southeast 1 08-11-2016 01:21 PM
Anybody can help me install a backup camera? dingledangle Northern California 0 12-01-2014 11:25 PM
Backup Camera Install in Houston Texas? NIN69 Cosmetic Modification (Interior/Exterior/Lighting) 18 06-18-2014 07:49 PM
Backup Camera Install Houston TX NIN69 Electronics | Audio | NAV | Infotainment 0 05-25-2014 01:27 PM
Backup camera install. Where to get it done, I'm near Macon and Atlanta dro Southeast 1 09-02-2013 12:38 AM
