| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
Link
Drives: 2015 Scion FR-S
VHT Tails gone wrong
I decided to smoke the stock tails cause I'm cheap but prefer self modding so anyways let's get right to it.
Materials used: VHT Night Shade Krylon Gloss Clear Coat Meguiars Ultimate Compound Turtle Wax Polish In short I cleaned the tails then wet sanded with 1000 grit. Applied 4 coats of VHT 15 mins apart of each other then after 4th coat I wet sanded with 1500 grit. 5 coats of Clear Coat then wet sanded with 2000 grit till smooth. Meguiars compound then polished. Still ended up with matte look. It looked glossy before I sanded the clear coat. Should I just apply a couple more coats of clear and avoid wet sanding it this time? |
[QUOTE=ckellykcco;2772014]I decided to smoke the stock tails cause I'm cheap but prefer self modding so anyways let's get right to it.
Materials used: VHT Night Shade Krylon Gloss Clear Coat Meguiars Ultimate Compound Turtle Wax Polish In short I cleaned the tails then wet sanded with 1000 grit. Applied 4 coats of VHT 15 mins apart of each other then after 4th coat I wet sanded with 1500 grit. 5 coats of Clear Coat then wet sanded with 2000 grit till smooth. Meguiars compound then polished. Still ended up with matte look. It looked glossy before I sanded the clear coat. Should I just apply a couple more coats of clear and avoid wet sanding it this time?[/QUOTE] That should work ......... ![]() humfrz |
Single part clear coat without an activator/hardener doesn't come out so great. It comes out as semi-gloss at best. Also 3k or 3500 sand paper would also help a little bit.
Spray 2k max is a good 2 part clear coat in a can.
| FS: Smoked Colins tails - PRICE DROP | Jas1137 | Canada Classifieds | 25 | 11-02-2018 07:26 AM |
| What did I do wrong? | Hags86 | Tracking / Autocross / HPDE / Drifting | 8 | 02-25-2015 01:36 PM |
| Trade: Black Spyder V1 Tails for Tom's Tails | Cross | Exterior Parts (Aero, Lighting, Etc.) | 3 | 07-05-2014 04:19 PM |
| This must be wrong... | Ongor | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 01-23-2014 11:29 AM |
| WTT: MY USDM Tails for your JDM/ADM/UKDM Tails | ZC6BRZ | Exterior Parts (Aero, Lighting, Etc.) | 2 | 01-16-2013 11:24 AM |
