Old 10-05-2016, 05:54 PM   #1
Dreamzqt
Drives: 2014 limited BRZ
How do I install this Carbon Fiber diffuser cover?
Just got it today heres a link to the product http://seiboncarbon.com/store/ta-sty...l#!prettyPhoto
http://imgur.com/a/aQmXr
http://imgur.com/a/zbx3t
Dreamzqt is offline   Reply With Quote
Old 10-05-2016, 05:59 PM   #2
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
3M
VIP BRZ is offline   Reply With Quote
Old 10-05-2016, 06:12 PM   #3
HachiRo
Drives: 2013 White-Out FRS
3M, but be careful. Buddy of mine has it and the sides don't hold as well over time so they get a bit unhinged. You wanna use a good solid piece of 3M above the reverse light as it's the most flat and holds the best.
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 10-05-2016, 06:13 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
It is Amazing tape.
Old 10-05-2016, 06:19 PM   #5
DAEMANO
Time Traveller
And don't forget to use this first....
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 10-06-2016, 11:56 AM   #6
RFB
RFB's Avatar
Drives: FRS
Originally Posted by Dreamzqt View Post
I have the same diffuser, tape will NOT work. What is recommended is red (heat) silicone. I used black gasket silicone. Used 2 large tubes.
4 years and hard tracking, holds fine.
RFB is offline   Reply With Quote
Old 10-06-2016, 03:00 PM   #7
Anderzz
Anderzz's Avatar
Drives: 2013 Subaru BRZ Premium
I have the Seibon one that wraps the whole rear bumper and diffuser and it's on with nothing but 3M
Anderzz is offline   Reply With Quote
Old 10-07-2016, 09:39 AM   #8
RFB
RFB's Avatar
Drives: FRS
In 2012, 3m tape for my 5 Axis body kit worked fine after a couple of minor lifts and re-applications, all due to slight warpage of parts. I thought it could work for the diffuser until someone more experienced advised me.
To avoid drilling and rivets I contacted Seibon and was told NOT to use foam tape, but to use red oxide (heat) silicone, as 3m over time will NOT hold .
The slightly warped diffusers have a poor fit over the soapy plastic, lots of air space which contributes to dirt accumulation, vibration etc. and LOOSENING. The diffuser is to heavy for tape.
The poor fit issue is well known and my importer accepts items that are dry fitted at time of purchase which don't fit, for full refund.
Silicone glue filling the gaps had enough shear strength to last permanently.
Peace of mind, knowing the carbon fibre diffuser will not fall off on the track or highway.
Old 10-07-2016, 10:30 AM   #9
Cole
Not a troll
Cole's Avatar
This is really good info, thanks for that!
Old 10-07-2016, 02:24 PM   #10
RFB
RFB's Avatar
Drives: FRS
YVW,
be sure to clamp both sides and use a heat lamp overnight -
Old 10-07-2016, 03:34 PM   #11
HMMMMM I knew this girl once...
Old 10-08-2016, 10:57 AM   #12
Dreamzqt
Can you send me a link to exactly what you used? Spent a lot of money yesterday and none of the things I bought worked
Old 10-09-2016, 10:37 PM   #13
Dreamzqt
Update just failed miserably at riveting now I have a ton of holes in my carbon fiber diffuser... they won't stay in I have no idea why
Old 10-09-2016, 10:45 PM   #14
Anderzz
Anderzz's Avatar
Why after all the suggestions, NONE OF WHICH SAID TO RIVET, would you decide to rivet? Rivets work via pressure that isn't compatible with the rigidity and lack of give in carbon...
Sent from my SM-G920T using Tapatalk
Looking for an oem style carbon fiber rear diffuser.. enjoi23 Cosmetic Modification (Interior/Exterior/Lighting) 6 05-13-2016 12:51 AM
Vis racing ams carbon fiber trunk and Seibon carbon fiber diffuser Mr.Frs Cosmetic Modification (Interior/Exterior/Lighting) 36 04-08-2015 10:51 AM
FRS/BRZ B1 Rear Diffuser Carbon Fiber Plastic Hot Toys Canada Classifieds 1 08-05-2013 04:39 PM
APR carbon fiber diffuser final gear Cosmetic Modification (Interior/Exterior/Lighting) 1 02-23-2013 01:27 AM
Carbon Fiber Rear Diffuser Tomzilla Cosmetic Modification (Interior/Exterior/Lighting) 5 11-17-2012 02:14 PM
