Northern California NorCal
Old 09-28-2016, 12:52 AM   #1
Zoh
Drives: None
Good car washing/detailing services in the South Bay?
Hey guys,
Had my BRZ for about a month now and while she's still beautiful, she's getting a little dirty and I think it's time to get her cleaned.
I'd do it myself, but A) I live in a building with an underground garage and don't have anywhere good to clean it and B) I don't really know what products and stuff to even use.
I was wondering if anyone has any recommendations on a good car wash service out here (Not automated. Hand wash.) ideally in the San Jose area?
- Zoh
Zoh is offline   Reply With Quote
Old 09-28-2016, 01:32 AM   #2
PRKR8NGR
Drives: Oceanic FR-S
Most 86 drivers I know, including myself, go to EZ Clean Carwash (524 Giuffrida Ave.)
PRKR8NGR is offline   Reply With Quote
Old 09-28-2016, 02:11 PM   #3
thatchmaster
Expensive for the higher end packages, but top work.
http://www.68autodetail.com
http://www.yelp.com/biz/68-auto-detail-milpitas-2
thatchmaster is offline   Reply With Quote
Old 09-28-2016, 02:38 PM   #4
darkonion
Habitual Troublemaker
darkonion's Avatar
Drives: 1997 Subaru Impreza, 2014 BRZ
Not really a service, but Optimum No Rinse might be super helpful for you.
https://www.amazon.com/Optimum-NR201.../dp/B00D8DR0AO
It is a concentrate, and depending on how much water you add to it, you can mix it for different purposes. Rinseless wash, clay bar lube, detail spray, etc.
Look on YouTube on how to do a rinseless wash. You might also want to check out the Garry Dean method.
I don't believe rinseless washes are as good as the traditional ones for cars that are really dirty, but I think they are just fine for upkeeping your car.
If you decided to get do a big detail service, I would also recommend inquiring about a nano-coating installation. Ask about Opti-Coat, CQuartz, or similar. It is a little pricey, but an install will help keep your car's paint a little more protected.
darkonion is offline   Reply With Quote
The Following User Says Thank You to darkonion For This Useful Post:
SmartedPanda (09-29-2016)
Old 09-28-2016, 11:16 PM   #5
FUN BRZ
Drive 2 Eat, Eat 2 Drive
FUN BRZ's Avatar
Drives: FUN SUPERCHARGED 2013 Limited BRZ
+1
FUN_BRZ <--- "Insta-Fun"
FUN BRZ is offline   Reply With Quote
Old 09-29-2016, 01:31 AM   #6
L8Apex
Drives: H8R FR-S
I hit EZ Clean Carwash on Giuffrida to blast off any heavy grime, then Optimum No Rinse inside my garage to get it super clean. You can use ONR in your underground parking no problem. Great stuff. I use it with a garden sprayer and a stack of clean microfibers.
"Understeer scares the driver; oversteer scares the passenger"
L8Apex is offline   Reply With Quote
Old 09-29-2016, 02:09 AM   #7
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
I recommend this product, just bought it.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 09-29-2016, 12:56 PM   #8
EastBayCanuck
Drives: Ultramarine FR-S
I use Griot's waterless wash and/or Meguiar's Quik Detailer all the time as I can't do water washes in my condo complex and it's just as good if not better than going through a touchless carwash. just need the spray's and like 3-4 microfiber clothes (more if you wash then "detail" or spray wax) and maybe 20 mins tops you are done.
EastBayCanuck is offline   Reply With Quote
Old 09-29-2016, 02:24 PM   #9
darkonion
darkonion's Avatar
I am glad that everyone has been having great experiences.
I like having a 3.5 gallon bucket with gamma seal lid. The lids are water tight. You can totally fill up the bucket with a wash or rinseless solution and easy transport it to wherever you are washing your car.
For cars that are quite a bit dirty, nothing wrong with taking it to a self wash place and hosing it down with pressured water before doing a rinseless wash. When I was an undergrad, I would fill the bucket with car wash shampoo and water and a washpad/mitt. I would then go to a self-serve place and wash my car there. I would use their water and soap gun, but I would use my bucket/Grit Guard/wash pad. I would never use the brushes at the car wash because I was always afraid that I would scratch my car.
Old 10-02-2016, 09:31 PM   #10
Zoh
Drives: None
So I ended up going to AJ's on Coleman today (68 is closed on Sundays, which seems like a great way to make less money to me) - Service was prompt and friendly, and the work was fairly solid. It's a little expensive, though still a tad cheaper than 68. Overall, pretty satisfied with the service.
Did the mini-detail + wax on their summer special for $59.99 + $10 tip
- Zoh
Old 10-03-2016, 03:48 AM   #11
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
If you dont have time to drive there check out Chemical Guys no water cleaner. Just spray on and wipe off with a microfiber. Takes a tad longer than a full wash but its great for touch ups or light layers of dust.
Xxyion is offline   Reply With Quote
Old 11-02-2016, 02:57 AM   #12
MyRx
MyRx's Avatar
Interesting quick read. I thought I'd bump it and put in my 0.02 since there really isn't a detail thread (correct me if I'm wrong, I didn't search).
Past few months in car shows and what not, I've had positive results with Chemical Guys and Meguiar's waterless/rinseless washing methods. Basically a concentrated formula that should be diluted with distilled water (follow mfg's instructions). Followed by either Chemical Guys wax and sealant OR Meguiar's products. Depending on when and how I wanted to prepare for the shows, I used these different waterless washing accordingly. I haven't traditionally washed my FRS since after the last track day (~ May/June).
So, for the wash-restricted owners, take a look at concentrated waterless/rinseless options. Keep it diluted and convenient in spray bottle and gallon jug of distilled water. Microfiber towels clean and in hand and wash it once a week. As mentioned above, don't use waterless/rinseless washing on a really dirty car but for upkeep, it works great. At the moment, I like Chemical Guys because it is easier to use. With Meguiar's stuff, I tend to use the polisher and different pads to get the results I want - could be psychological too since I've always used a polisher with these brands that have existed for a while. Either way is fun really.
ONR is good too. The sample I had I liked. With any choice of waterless washing though, technique is key.
The Following User Says Thank You to MyRx For This Useful Post:
SmartedPanda (11-05-2016)
Old 11-02-2016, 07:16 PM   #13
darkonion
darkonion's Avatar
Optimum were the people that really revolutionized the rinseless wash formula. I've tried the Chemical Guys stuff. I've never really thought that highly of Chemical Guys stuff. There are a few things that are good, but most of it is kind of bleh.
What is important is what works for you. If you like CG, by all means... use it. If you only like CG because their products are better bang for the dollar, that's not bad either.
Believe it or not, a lot of the result is based on technique, and not what chemical you use.
Old 11-03-2016, 02:48 AM   #14
tysoNgwaNg
awesome.
tysoNgwaNg's Avatar
Drives: 1994 Toyota Celica, 2014 Scion FRS
AJ's off coleman
tysoNgwaNg is offline   Reply With Quote
Detailing, Opti Coat Pro installs, and Clear Film Services in Northern NJ DetailersDomain NY / NJ / CT / PA 14 09-22-2015 08:15 PM
Washing and Detailing LostSalad AFRICA 11 06-08-2015 03:15 PM
I have no idea what I'm doing and need some help! [washing, detailing] Ammunition Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 14 11-17-2013 01:59 AM
A good place for Car Detailing? Lverasky Northwest 4 03-09-2013 01:18 AM
XSXV: South Texas Paint Correction & Detailing goat_cheese Cleaning and Detailing 6 10-17-2012 11:11 PM
