Old 09-15-2016, 12:20 AM   #1
SpeedDemon26
Question Window won't go up! HELPPPP!
So, my passenger window stopped working last week. So today when messing with it it would go down, but not up! It only responds from the passenger side window control too. I've tried using the drive side switch and no movement in either direction and not audable noise of the motor clicking. When I press the button for the window to go up it doesn't move nor make a noise. But when the window was all the way up I was able to fully roll it all the way down (but sadly not back up). I'm completing stumped on what's broke: the window motor, the passenger switch, driver switch, or does my car just hate me for leaving it sitting for two months?
SpeedDemon26 is offline   Reply With Quote
Old 09-15-2016, 01:08 AM   #2
humfrz
FIRST OFF, @SpeedDemon26 you only have to post in one section ...... .....if you double post it just gets us old guys confused ....
OK
First thing I'd check is the fuse. It's in the #14 slot (25A) in the fuse box under the hood.
While you're there, might as well check the other sides fuse also (#10 position).
If the fuse is OK, the next thing I would suggest to do it take the switch out and test it.
Then we can go from there .....
Calling @Ultramaroon - he is a window expert .....
humfrz
Old 09-15-2016, 01:39 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Should I change my answer to balance things out?
Old 09-15-2016, 02:18 AM   #4
humfrz
Nah ......let him look for it.
humfrz
Old 09-15-2016, 04:21 AM   #5
WesleyG
Drives: 2014 Satin White Pearl GTS auto
Have you checked if the window lock switch isn't accidentally pressed in?
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
Old 09-15-2016, 08:36 AM   #6
SpeedDemon26
OK
humfrz
Sorry for that! I posted in the wrong area first so tried to repost and delete the wrong one but couldn't..
My 2013 Scion FR-S doesn't come with a window lock switch. Unless it's a hidden feature I was never told about haha
Old 09-15-2016, 09:26 AM   #7
Pretty sure it does. This is a photo from mine. Upper left button.
Old 09-15-2016, 09:54 AM   #8
SpeedDemon26
I tried both fuses by the way and it didn't fix the problem. I appreciate the idea though!
Old 09-15-2016, 10:18 AM   #9
Check the reinitialization process in your manual.
Old 09-15-2016, 10:30 AM   #10
SpeedDemon26
Well ya see I would... But the kind sir that sold me this car didn't include one.
Old 09-15-2016, 10:36 AM   #11
http://m.scion.ca/scion/en/m/owners/manuals can get a pdf manual here.
Old 09-15-2016, 12:24 PM   #12
Ultramaroon
not playing cards
Well, did you toggle the nonexistent switch yet? We're all holding our breath here. Slow day in FT86-land.
Old 09-15-2016, 01:11 PM   #13
SpeedDemon26
Well I found that darn switch y'all were talking about. Buttttttt, still doesn't work
Old 09-15-2016, 03:02 PM   #14
Ultramaroon
not playing cards
Oh, dammit. It would've been too easy. Well, if you've verified the fuses, are handy with a multimeter, and don't mind removing the driver's side door card we can continue. Otherwise, I recommend a pro.
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
Drivers window grabbing window seal and pushing it up. stockysnail Issues | Warranty | Recalls / TSB 22 12-22-2015 01:08 PM
Gas Problem maybe? Helpppp speedy07 Issues | Warranty | Recalls / TSB 18 12-12-2015 04:04 PM
My exhaust setup produces wayyyy to much rasp. Helpppp BoostedWrbBrz Engine, Exhaust, Transmission 12 07-27-2014 01:14 PM
Window Scratched by Window Motor / Lifter? tomkozski Issues | Warranty | Recalls / TSB 22 05-31-2014 07:25 AM
