Old 09-11-2016, 10:25 PM   #1
HemiGoesHam
Drives: 2013 Subaru Brz
THE BEST BRZ/FRS COILOVERS?
So I'm not looking for the best coilovers lol. I just want to know what you guys think are good coilovers. I'm going to run Vossen CVT'S 19x8.5 +45. The goal of the coilovers is to get a lower height. Since Vossen wheels smallest size are 19 inches I need to drop the car a inch or two to get a good look. I'm not tracking this car, but I want a good ride. I don't want the top of the line coilovers I want best bang for your buck or great quality coils.
HemiGoesHam is offline   Reply With Quote
Old 09-11-2016, 10:59 PM   #2
RJasonKlein
RJasonKlein's Avatar
Welcome to the forum.
Now that that's out of the way....I'm not trying to crap on your dream, but 19" wheels (particularly a heavy cast wheel like the Vossen) will really diminish your handling. I understand the look you're after and it is visually appealing, but proceed with caution. There's a ton of information on this forum about handling, wheel options, and everything else you need to know about upgrading and getting the most out of your car - I'd really suggest that you spend some time doing research before you make your purchase.
As for coilovers, you have a ton of options...but coilovers may not be the best option for you. Aside from the ability to lower your car, why do you think coilovers are a necessity?
RJasonKlein is offline   Reply With Quote
The Following 3 Users Say Thank You to RJasonKlein For This Useful Post:
Captain Snooze (09-12-2016), kch (09-12-2016), Shark_Bait88 (09-14-2016)
Old 09-11-2016, 11:07 PM   #3
Tokay444
The best dampers are Penske.
/thread.
The Following 5 Users Say Thank You to Tokay444 For This Useful Post:
cdrazic93 (09-13-2016), CSG Mike (09-12-2016), DAEMANO (09-14-2016), DriveDriftDogfight86 (09-19-2016), Shark_Bait88 (09-14-2016)
Old 09-11-2016, 11:15 PM   #4
HemiGoesHam
Yeah I have seen those wheels are a tad too big. I'm still considering a couple of other wheels. Well the main reason I want coilovers is adjustable height. I want to be able to adjust the height at all times. I also want to improve the handling of the car. Eventually, hopefully, maybe, I would like to drop a turbo or a sc in the car.
Old 09-11-2016, 11:23 PM   #5
HemiGoesHam
Old 09-11-2016, 11:46 PM   #6
RJasonKlein
Got it, and I'm glad to hear that you're still shopping and doing research. Here's a great sticky thread that covers wheel fitment and shows tons of wheels on our cars:
http://www.ft86club.com/forums/showthread.php?t=7535
Pay particular attention to offset and weight, and fight the urge to go crazy wide - the car will generally be slower and less fun to drive.
As for solid coilovers on a budget, here's a thread from today that recommends ST Suspensions coilovers:
http://www.ft86club.com/forums/showthread.php?t=110568
While I don't have first hand experience with them, they are wholly owned by German giant KW Automotive and seem to be coming up frequently in threads here on the forum. Keep in mind all of the entry-level coilovers have limitations, but they seem solid and worth a look, along with various other offerings from Racecomp Engineering (also KW Automotive based) and Tein.
I hope this was helpful. Good luck and, once again, welcome to our community!
Last edited by RJasonKlein; 09-12-2016 at 05:39 PM. Reason: Corrected a typographical error.
Old 09-11-2016, 11:47 PM   #7
RJasonKlein
Duplicate post - moderators, please delete.
Old 09-11-2016, 11:54 PM   #8
HemiGoesHam
Thank you for the wishes! Last question lol. I was checking out a forum on most of the coils that are recommended and I found a thread ( http://www.ft86club.com/forums/showthread.php?t=13553 ) and the review on these coils is amazing. My question is, do you have any thoughts?
Old 09-12-2016, 12:05 AM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
HemiGoesHam: Adjustable height all times as in dynamically like air suspension. Also not cheap option (IIRC ~ $3.5K). And you do understand, that car will need alignment done after each height change? In most cases with dynamic height change alignment is done for setting you will drive most of time and other heights are used just and only temporary, eg. if slam park or to clear some speed-bump or driveway, if "normal" is set/aligned for something stupidly low. If you care about handling, i certainly wouldn't install big heavy wheels like 19" are, that will worsen acceleration/comfort for very slight sharper turn-in. In sport, many often use smallest wheels possible that still clear brakes for weight reason. For example gazoo racing series gt86-s with 16" tws t66-f. 17" for many other cases.
P.S.
Best coilovers .. most probably out of your budget. +1 to custom Penske-s.
Old 09-12-2016, 01:33 AM   #10
RJasonKlein
I'm sorry, but I have no experience with D2 Racing coilovers - I checked their site, however, and it looks like their line has changed since the post you linked to from 2012.
Old 09-12-2016, 04:10 AM   #11
MeisterR
MeisterR's Avatar
Drives: BNR32
As other say, there really isn't a "best" coilovers out there.
It is a complete package, and the "best" coilovers I define as the best solution to your need within your budget.
And everyone have different need, so the best solution is different depending on that.
However, I would say you need to define your need a little more.
Lower height: How low?
The FR-S / BRZ suspension is actually very limited in terms of how much damper travel it has.
What that mean is if you want to be slammed to the ground, it will be different to a suspension that is designed to lower the car but not slammed.
This design difference affect ride comfort.
If you want the car very low, chances are you won't have the damper travel within the suspension for a nice ride.
So you got to figure out all that first before we can realistically recommend you.
Without knowing what you want exactly, people are just throwing up brand names.
The right suspension for your need is what you want.
Jerrick
MeisterR is offline   Reply With Quote
Old 09-12-2016, 01:33 PM   #12
kch
Senior Misanthrope
kch's Avatar
Others have mentioned this, but I feel it needs emphasis:
1) It's a total pain to adjust the height of your coils. Like...a huge pain.
2) You should really get an alignment every time your ride height changes. Changing height will screw up your rear toe (among other things) and you'll feel all floaty and out of control. You'll also kill your tires.
There's always airlift, but that's usually only set up for two positions: (1) driving height (which is what you use for your alignment); and (2) hardparking.
Old 09-12-2016, 06:45 PM   #13
HemiGoesHam
Jerrick
No I don't want the car slammed. I just want to lower it 1-2 inches. I also want to improve handling of the car
Old 09-12-2016, 11:08 PM   #14
MeisterR
MeisterR's Avatar
Drives: BNR32
If this is low enough for you, then the MeisterR ZetaCRD+ coilovers could do what you are asking for.
Sensible springs rate (5/4 kg/mm) as well as adequate damper travel mean you can achieve a lower ride height while having good performance.
The damper valving are engineered by MeisterR in our UK workshop along with our technical partner, so they are design to give compliant ride quality as well as good traction over uneven road surfaces.
But like other said, coilovers are really design for 1 ride height.
So you can't just change the ride height all the time as alot of other things need adjusted along the way (such as alignment).
I can't say MeisterR are the "best", but certainly a contender at this price bracket.
Jerrick
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
FREE Shipping: ISC N1 Coilovers: ST Coilovers in stock at B2autodesigns b2autodesigns Brakes, Suspension, Chassis 177 02-09-2015 11:34 AM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 12:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 08:56 PM
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers ill roller Brakes, Suspension, Chassis 5 12-14-2013 03:02 PM
