Old 09-01-2016, 09:55 PM   #1
treminaor
"DGM BRZ"
treminaor's Avatar
Drives: 2016 BRZ Limited
[Image] Example of Spring Drops on Stock Wheels
I'm currently trying to make a decision on what drop height I want with lowering springs on my stock wheels and I haven't been able to find any good image examples on Google - most either already have bigger wheels on their car or took the image at an inconsistent angles and it's hard to directly compare, so I used photoshop to emulate the drop heights.
I measured the wheel gap on my stock BRZ and converted it to the pixel amount of the stock height in this photo I found on Google. I then converted pixels to inches in order to emulate certain drop heights. I did most of the common heights, ignoring ones that were within a quarter inch of another height I already had in the image - very hard to spot the differences in those anyway.
Here it is, hopefully it helps some people:
Of course let me know if someone already made something like this or if there's an error in mine
After making this image I think I decided on a 1.4" drop for my car, just FYI.
treminaor is offline   Reply With Quote
The Following User Says Thank You to treminaor For This Useful Post:
Mr.Impreza (09-02-2016)
Old 09-01-2016, 10:28 PM   #2
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Are you planning on keeping the stock dampers? If so, I wouldn't go any lower than 1" at most. Any lower and you're losing a lot of travel and they will wear out pretty quick.
smg1138 is offline   Reply With Quote
The Following User Says Thank You to smg1138 For This Useful Post:
wparsons (09-02-2016)
Old 09-01-2016, 10:34 PM   #3
treminaor
"DGM BRZ"
treminaor's Avatar
I can't afford better dampers or I would have just bought coilovers from the get-go. I didn't think the extra .4" would be that much added stress but if so then maybe I should reconsider... 1" was originally what I planned to do until I visualized the difference between 1" and 1.4".
Also if it makes a difference in your advice, this is my DD and I never track. Backroads are as close as I get.
Old 09-02-2016, 09:41 AM   #4
smg1138
smg1138's Avatar
If you want your stock dampers to last, don't go too low or too stiff. The Eibach Pro Kit is a popular option that gives a 1" drop. I'm pretty sure Toyota actually rebrands those for their TRD springs. For more performance, you can't go wrong with the RCE Yellows, but they only have a 20mm drop.
Another thing to keep in mind is suspension geometry. If you drop much below 1" you could start running into bump steer. Also, your rear negative camber can get pretty extreme as you drop lower if you don't have adjustable lower control arms to fix it.
Old 09-02-2016, 12:08 PM   #5
wparsons
wparsons's Avatar
There's only about 2.5" of bump travel stock, a 1.4" drop leaves very little travel. You'll need high spring rates to keep from bottoming out all the time, which is harder on the stock shocks.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
smg1138 (09-02-2016)
Old 09-02-2016, 12:23 PM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
that extra .4" is a big difference. Stick with the 1" drop. Comfort and handleing will be much better. RCE yellows are some of thebbest springs for DD/canyon I could reccomend. Swift Sports and Mann Engineering springs are pretty good too.
Old 09-02-2016, 01:52 PM   #7
treminaor
"DGM BRZ"
treminaor's Avatar
Thanks everyone for the clarification, I'll stick to 1" or less.
I like that the Swift springs are a full 1" as opposed to the ~0.75" with the RCE Yellows. Is there a significant performance difference?
Edit: After looking specifically at the FRS/BRZ spec Swift springs it looks like they have the same drop as the RCE Yellows...
Old 09-02-2016, 02:19 PM   #8
finch1750
finch1750's Avatar
Not really. Square rates vs. staggered so the swifts will be a little more tail happy in theory. get a good alignment and should be perfect on either
Old 09-02-2016, 04:10 PM   #9
shellslinger
Drives: Whiteout FRS
What's your budget? You can probably snag a set of used or new Tein Flex Z coilovers for not much more for a spring set.
shellslinger is offline   Reply With Quote
Old 09-02-2016, 05:40 PM   #10
treminaor
"DGM BRZ"
treminaor's Avatar
Really? I could probably afford to drop $400-500 if I was getting a set in good shape. Where?
Old 09-02-2016, 08:17 PM   #11
shellslinger
These are not Flex Z's but here's a set of ST Suspension
http://www.ft86club.com/forums/showt...nsion&page=593
Old 09-02-2016, 10:52 PM   #12
treminaor
"DGM BRZ"
treminaor's Avatar
Although it's tempting I'm contemplating just waiting for my stock struts to wear out before I invest in some coilovers - I've only got 10k miles on the car so far so they have a while to go. Those STs are quite a deal though.
Image Wheels - Exclusive USA Distributor - Custom Made in UK GuerillaRacing Wheels and Tires 30 10-06-2014 04:45 PM
WTB RCE spring or RS*R spring mounted on stock strut jshum Want-To-Buy Requests 1 10-11-2013 02:47 PM
Image Wheels - Great Britain miodculae Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-25-2012 01:50 PM
