Old 08-30-2016, 12:21 AM   #1
alecp
Drives: 2014 Subaru BRZ Premium
BRZ to FRS Headunit -- no sound
Just swapped the 2014 BRZ Fujitsu Headunit for the 2015 FRS Pioneer Headunit, and everything works (antenna, bluetooth, usb) except for no sound whatsoever. I quintuple-checked all of the connectors. Anyone have a guess what the problem could be?
alecp is offline   Reply With Quote
Old 08-30-2016, 08:41 AM   #2
Try disconnecting the battery for a few minutes. Some other guy had the same issue and that worked for him. Guess it just needed to reset or something.
alecp (08-30-2016)
Old 08-30-2016, 11:30 AM   #3
alecp
I'll try this tonight!
Old 08-30-2016, 11:32 AM   #4
No guarantees but worth a shot.
Old 08-30-2016, 09:00 PM   #5
alecp
Nope! Disconnecting the battery didn't change anything -- still the exact same behavior. Sadly =(
The Following User Says Thank You to alecp For This Useful Post:
Tcoat (08-30-2016)
Old 08-30-2016, 10:13 PM   #6
Damnit!
Old 08-30-2016, 10:20 PM   #7
gramicci101
Off Topic
Do the two have the same pinout?
Old 08-30-2016, 11:10 PM   #8
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
^^^ this. Doesn't the FRS and BRZ have different pin outs for the amp turn on wire? Try playing with the fader, is it absolutely no sound, or just no sound from the door panels?
Pointmutation is offline   Reply With Quote
Old 08-31-2016, 03:57 AM   #9
alecp
From what I have found, the pinouts for the two are nearly identical and are identical for functionality purposes.
Reference: http://www.ft86club.com/forums/showp...8&postcount=20
In the 10 pin harness, both the BRZ and FRS have the amp turn-on at pin 9.
The difference is the AM/FM antenna booster amplifier power on pin 8. In the Subaru version it is provided by the headunit, but in the FRS it is a No-Connect. So the difference is that no power is going to the to the antenna booster amplifer. But this wouldn't kill the power to the speakers, presumably?
There is no output from any speakers at all, not just the door/dash speakers.
Hrmm
Old 08-31-2016, 11:44 AM   #10
gramicci101
Off Topic
The antenna booster wouldn't affect output to the speakers, so that's not an issue. All the speaker outputs are the same, and that's the important part. The fact that you're getting no sound from any of the speakers, not just the door speakers (rear amp), makes me think that it might be a problem internal to the radio. Can you swap the BRZ radio back in and see if the speakers work again?
Old 08-31-2016, 11:56 AM   #11
Chimera
Drives: FRS
I was about to suggest the same, that sounds an awful lot like a bunk radio
a quick test if you have some parts you could get the Metra harness hook up power and ground from a 12v source if you have one, (a car battery will work, but a powerblock is safer/easier) and run 1 speaker.
Old 08-31-2016, 12:01 PM   #12
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
It's very unlikley that all the speakers went bad the moment you installed a new radio.
If you are sure about the compatibility of the new radio, check for damaged pins on the wiring harness (es) They dont always line up properly and can get pushed back into the harness if you get in hurry. If all that is good and the radio is really supposed to be plug and play, then the radio is the prime suspect.
Twinz is offline   Reply With Quote
Old 08-31-2016, 06:18 PM   #13
alecp
The speakers do work independently. I swapped back to my original Fujitsu Ten headunit, and the speakers pick up and play audio immediately.
The harness definitely works as well, since I am reusing the same harness between headunits.
I think it's clear that the headunit I got is broken. Just wanted to explore all options before arriving at that conclusion.
Thanks for everyone's input. I do appreciate it.
Old 09-01-2016, 01:46 AM   #14
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
Technically, on FR-S HUs the HU does still provide that power, but it's via the tiny pin on the AM/FM connector.
Some HUs (including OEM ones) will disable the speaker amplifier IC (killing all 4 speaker outputs) if any one of them is shorted. Typically that happens after people do something wrong while replacing speakers or doing something in the doors, but in your case it could be a problem inside the HU.
SVXdc is offline   Reply With Quote
The Following User Says Thank You to SVXdc For This Useful Post:
alecp (09-01-2016)
Please help, Joying headunit powers on, no sound. I've already searched forum! Gareth Electronics | Audio | NAV | Infotainment 4 07-29-2016 10:57 AM
Does this sound deal sound decent ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 29 11-21-2015 11:02 AM
Drone (Worn Wheel Bearing SOund) Sound From Rear qbzee007 AFRICA 8 11-14-2014 02:04 AM
BRZ headunit problem USB sticks & headunit reset..school me. Photonic Electronics | Audio | NAV | Infotainment 2 03-12-2014 07:06 PM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 10:57 AM
