Old 08-28-2016, 06:02 PM   #1
VinJah
Drives: Blue Scion FR-S
how to get 245 18's to fit
Right now I have stock wheels and stock suspension and was wondering what I should do and the exact specs so I can completely avoid rubbing.
VinJah is offline   Reply With Quote
Old 08-28-2016, 06:16 PM   #2
Marcbrz86
Drives: 2015 Subaru BRZ Series Blue
245 will fit front and rear no problem. If you are getting 18x9 you may poke in the front depending on offset but that can be fixed with camber bolts
Marcbrz86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Marcbrz86 For This Useful Post:
Mvhs09 (09-25-2016), SkAsphalt (08-29-2016)
Old 08-28-2016, 06:25 PM   #3
VinJah
So these would work? http://www.wheeldude.com/catalog/pro...oducts_id=6448
Would I need to get coil overs or could I lower it an inch with springs and have no problems?
Old 08-29-2016, 10:58 AM   #4
Synkopy
Dragon King of Jupiter
Drives: 2016 BRZ Hyperblue
18x8.5 +44 should clear the front spring perch no problem. You'll have a mile of room in the rear. You'll want to run a 35 series tire. (245/35r18) but you shouldn't have an issue fitting those wheels. And most likely won't poke at all.
Synkopy is offline   Reply With Quote
Old 08-29-2016, 10:16 PM   #5
Marcbrz86
You won't need coilovers. Like Syn said you'll have no problems at all
Old 08-29-2016, 10:41 PM   #6
gMit
Drives: Pearl BRZ
Hey guys, want to piggy back on this. I want to run 18x9.5 +43 with 245/35 tyres. Plan on putting it on coilovers. Does anyone think I would have rubbing issues without adjusting camber?
gMit is offline   Reply With Quote
Old 08-29-2016, 11:15 PM   #7
Synkopy
gMit, you'll be cutting it close. I'm not sure the wheel will fit without contacting the spring perch. Once you get coils you should be fine, but I'd definitely get them before fitting the wheels. Also might consider a lower offset. Somewhere in the +38 ish ballpark. Just my 2 cents.
The Following User Says Thank You to Synkopy For This Useful Post:
gMit (08-29-2016)
Old 08-29-2016, 11:37 PM   #8
gMit
Drives: Pearl BRZ
Wheels in question are Enkei rs05rr. Would really love the semi concave face. Of course I'd have to go coilovers. The lower offset ones change to 18x9 + 40 but change the face.
Old 08-30-2016, 12:59 PM   #9
Synkopy
An 18x9 +40 is a perfect fitment in my opinion. But I definitely understand. Just remember that the 9.5 +43 will be nearly 10mm closer to your suspension. I can say for sure if it will fit or not. Definitely not with stock springs. Have you checked the wheel directory to see if anyone is already running the setup you want. Might find some useful info there.
