Old 08-19-2016, 09:54 AM   #1
Jhood
Jhood's Avatar
Drives: 2014 BRZ Limited [6MT/SWP]
SOLD!!
I have a Crawford AOS kit I bought a few months back, I had planned on needing a return system for my catch can setup, but now just swapping over to VTA. The kit has about 6,000 miles on it, never had an issue with it. Comes with everything you normally get in the box; the can, all the hoses and zip ties, & I also have a 3/8" check valve clamped into the line going from the can back to the manifold to avoid the AOS from seeing positive boost pressure and sending it into the crank case.
I will also include a longer hose that I purchased to reach the front of the engine bay for tapping into the intake pipe, with a nipple attached to plug into the coupling OR intake as shown in the picture highlighted in red. Normally the top port is plugged into the OEM air intake, but this obviously becomes an issue when boosted, so as you see I just tapped it into the new air intake making sure it went before the turbo to not cause any leaks, and it worked fine, didn't cause any oil residue on the turbo when removing the coupling to check.
Price is $200 shipped to anywhere in the US only (lower 48). System is good as new, non negotiable.
|FBM Stage 1 Build|GTX2867R|
|Moto-East Flex Fuel & Dyno Tune|
|360whp / 265tq (E81 @ 12psi)|
Jhood is offline   Reply With Quote
Old 08-19-2016, 10:08 AM   #2
-Phil
Drives: Rb25 neo brz
Wrong section
-Phil is offline   Reply With Quote
Old 08-20-2016, 11:23 AM   #3
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Please follow the Member Classified Rules (#2) or I'll delete the thread.
2. You must post AT LEAST ONE picture of the item(s) for sale with a sign included in the photo. On the sign, should be your username, date and the words FT86Club.com on it. It can be handwritten or printed on a piece of paper. No photoshopped signs will be accepted.
Thanks,
ichi
Old 08-21-2016, 08:55 AM   #4
himbo
Drives: Lightening Red BRZ Ltd.
Pm sent
himbo is offline   Reply With Quote
For Sale: Crawford Billet Power Blocks..New never been opened hardware. dc2stud NY / NJ / CT / PA 0 07-25-2016 05:46 PM
Crawford AOS Whitel Engine, Exhaust, Bolt-Ons 5 06-15-2016 05:06 AM
Crawford AOS Nhan55nguyen Engine, Exhaust, Bolt-Ons 2 06-03-2016 07:05 PM
Crawford AOS pleong Engine, Exhaust, Bolt-Ons 3 08-26-2015 08:16 AM
For Sale: RobiSpec Rad/Oil-Cooler, Crawford BPB, APEXi, Setrab RehabJeff86 Engine, Exhaust, Bolt-Ons 12 08-11-2015 01:39 PM
