Old 08-18-2016, 04:05 PM   #1
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Continental Extreme Contact DWS
In another thread, these tires were questioned, so has anyone mounted these tires specifically...what did you think...please keep on topic...thanks!
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 08-18-2016, 04:09 PM   #2
jasonojordan
Drives: 2013 satin white brz limited
Since you started a thread on it ill clarify further on them. They are a good tire just not a good tire for the brz as a summer tire. Also to answer your question no the premicy tires that come stock have a stiffer sidewall then these do. If you are looking to drive this car year round you really need two sets of tires one all season set will not cut it.
jasonojordan is offline   Reply With Quote
Old 08-18-2016, 04:12 PM   #3
paiceyfan
paiceyfan's Avatar
...but it's a good point...I didn't realize that the sidewall might not be as stiff as I expect...I guess I will see.
Old 08-18-2016, 04:13 PM   #4
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Great tires for a daily driver that sees the occasional snow, by a pedestrian driver.
I don't like all seasons, as they really aren't good for anything other than the awkward few weeks where one morning it'll be 36 degrees, and later that afternoon it'll be 75.
If you've got an Edelbrock supercharger on your BRZ, buy PROPER summer tires. DO NOT cheap out there. It's what connects you to the pavement and allows you to go, stop, and corner.
If you're looking to save some money, you can always run inexpensive summers, (V12,) and winters, (altimax arctics,) to have good year round performance affordably.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 08-18-2016, 04:15 PM   #5
jasonojordan
If you want to stick with the continentals I recommend the Continental DW tires. Good in the dry and wett, suffer under 50degs for traction however. I have 245 on the front and 265 on the back of my brz.
Old 08-18-2016, 04:17 PM   #6
brz11b
Drives: United States
Depends on your goals. i have these tires. 265/35/18 squared on my brz right now.
My car is 99% spirited street driven. Its not my daily so I try to keep it garaged when it rains but living in Louisiana thats not always possible. For the driving i do the tires are great, they grip fine, they hold up in rain and water fine and the tread life is great on them. I bounce back and forth between and Florida, there is only hot, hotter and rainy as far as seasons so these tires are fine for the type of driving i do and the weather i encounter. There are defiantly better tires out there for weather or for grip or for sidewall stiffness but these are a good all around tire. I'm looking forward to seeing how long and well these hold up for.
brz11b is offline   Reply With Quote
Old 08-18-2016, 04:19 PM   #7
jasonojordan
Your referring to the DW not the DWS here correct?
Old 08-18-2016, 04:22 PM   #8
brz11b
Nope DWS. I almost went with DW but ended up going with DWS, i believe they are the DWS 06.
Old 08-18-2016, 04:48 PM   #9
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
I have the DW 245/35/18, immense difference from stock tires. I can push the car to the turn/curve way more to the limit. No more skidding after 1st gear pull and turn either. Don't know much about DWS but they are highly rated as well, and would probably offer more traction.
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 08-18-2016, 06:12 PM   #10
paiceyfan
paiceyfan's Avatar
So, is there a difference between DWS and DWS06?
Sent from my XT1031 using Tapatalk
Old 08-18-2016, 06:13 PM   #11
brz11b
I think its jut tread pattern but i could be wrong.
Old 08-19-2016, 10:25 AM   #12
JazzleSAURUS
Do yourself a favor and grab the DW next time if you like your contis! A summer tire will do a better job evacuating water and gripping. As long as your car doesn't see snow or freezing temps, it'll be a way better choice.
Old 08-19-2016, 10:32 AM   #13
ZionsWrath
Thanks
ZionsWrath's Avatar
They aren't horrible but not grip monsters. Though I think they have more grip than my heat cycled OEM Primacy now. Id rather summer/winter dedicated though. All season is so meh now that I have had dedicated sets.
Old 08-19-2016, 11:29 AM   #14
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I have the DWS 06's on my car. And for daily driving, they are great. The grip is better than I expected, but honestly, next time I'll just get the regular DW for better summer grip.
MS, CSCS, TSAC-F, CPT
Continental Extreme Contact 265-35-18 Mvhs09 Wheels and Tires 4 08-14-2016 06:39 PM
225/50/16 Continental Extreme Contact DW makesdrivingfunagain Wheels and Tires 2 08-25-2015 08:02 PM
2 Continental Extreme Contact DW 245/35/18 (SF east bay) serial gixxer Wheels and Tires 6 02-23-2015 01:05 AM
Continental Extreme Contact DW vs. MPSS? Whats that smell? Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 12-24-2014 07:47 AM
Continental Extreme Winter contact vs Blizzak w70 Double4Free Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 11-29-2012 11:36 PM
