Old 08-18-2016, 12:38 AM   #1
xcuz31
Drives: white frs
CNT, ARM or OBX UEL header?
any you have experience on any of this 3 headers?
CNT, ARM or OBX.
what header will you recommend for me
i am on a budget .
i searched the forum but no reviews so far for this 3 headers
xcuz31 is offline   Reply With Quote
Old 08-18-2016, 03:27 AM   #2
steve99
Gruppe -s is likely the best bang for buck well made good fitment for less tha $500
those other headers are a bit ordinary in fitment and quality
link
http://www.ft86club.com/forums/showthread.php?t=81839
maybe read the basic bolt on mods guide link below
Old 08-18-2016, 08:40 AM   #3
Teseo
Drives: frs
http://www.ft86club.com/forums/showthread.php?t=81491
Old 08-18-2016, 09:40 AM   #4
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Used.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 08-18-2016, 09:58 AM   #5
shellslinger
Drives: Whiteout FRS
I'd go with Gruppe-S very good quality header for the money.
shellslinger is offline   Reply With Quote
Old 08-18-2016, 01:57 PM   #6
KendallH
Drives: 2013 FR-S Base, 1997 Jeep Wrangler
Stay away from CNT. Mine started leaking at the flange (engine side) about a week after I installed it. This was with brand new OEM gaskets.
KendallH is offline   Reply With Quote
Old 08-18-2016, 02:03 PM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Save more and get gruppe-s/ofh/rev works used. The others are garbage
Old 08-18-2016, 02:53 PM   #8
xcuz31
Drives: white frs
ah ok thanks will oft will remove the CEL for o2 sensor? and is it safe to run without an actual dyno tune
Old 08-18-2016, 03:17 PM   #9
BWilky
BWilky's Avatar
Drives: 2016 Subaru BRZ WRB
The general rule is without a tune, you will get a CEL light and not get the full potential from the header swap.
BWilky is offline   Reply With Quote
Old 08-18-2016, 07:01 PM   #10
xcuz31
Drives: white frs
ah ok how about the OFT out of the box tune will it remove the cel of a header?
Old 08-18-2016, 07:17 PM   #11
steve99
OFT comes with tunes for catless uel headers for 91/93/E85 fuels and oft tunes like all other tunes for catless headers will improve performance and disable P0420 cel code
you can run catless header without tune but you miss out on a lot of the gains and you will get CEL code which will disable Cruise control.
you can try o2 spacer in rear 02 sensor, but better option is tune
OFT info see here
http://www.ft86club.com/forums/showthread.php?t=71157
General basic bolt on mods guide
http://www.ft86club.com/forums/showthread.php?t=81493
Teseo (08-18-2016)
Old 08-19-2016, 05:04 PM   #12
bababooey
Drives: BRZ SWP Limited -6MT
ive got cnt and havent had much issue with it. had to beat it slightly with mallet to get one of the flanges on the engine studs on one side but i suspect that may occur with other brands as well. its been great for me being a budget piece. there is a thread or two with mostly positive reviews.
Old 08-19-2016, 05:20 PM   #13
DAEMANO
Time Traveller
Also have a CNT UEL which worked great with no issues whatsoever. I took it off the car for a smog and will probably be going EL so I'll sell it. I rather enjoyed it while it was on the car and have no regrets.
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
