Old 08-17-2016, 07:49 PM   #1
ZeroTo86
ZeroTo86's Avatar
Drives: '13 FR-S Turbo (Greddy T620z)
CUSCO Oil Cooler w/ FREE Pre-Cut Samco Radiator Hoses! $450 ($700+ retail)!
SOLD!
ZeroTo86 is offline   Reply With Quote
Old 08-20-2016, 12:20 AM   #2
ZeroTo86
ZeroTo86's Avatar
Bump
Old 08-22-2016, 07:22 PM   #3
ZeroTo86
ZeroTo86's Avatar
Bump
Old 08-26-2016, 02:40 AM   #4
ZeroTo86
ZeroTo86's Avatar
Bump
Old 08-28-2016, 09:01 PM   #5
ZeroTo86
ZeroTo86's Avatar
Price lowered considerably!
Old 08-30-2016, 09:23 AM   #6
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Any engine bay pics of this installed?
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 08-30-2016, 10:48 PM   #7
ZeroTo86
ZeroTo86's Avatar
This is the best pic I got. You can see it 'tap' into the samco hosing and route back to the plate.
The Following User Says Thank You to ZeroTo86 For This Useful Post:
JazzleSAURUS (08-31-2016)
Old 08-31-2016, 05:46 PM   #8
Mirageo
Drives: Subaru BRZ
How was the efficiency btw? Curious! Since this is cooled with coolant from the radiator right?
Mirageo is offline   Reply With Quote
Old 08-31-2016, 11:34 PM   #9
ZeroTo86
ZeroTo86's Avatar
Even with boost (and hitting boost) on a hot day on the highways, I rarely would hit over 200s and usually stick around 197F (I never canyon'd or track'd with this car so can't speak about that). The best part about this type of oil cooler is it warms up faster; so you get to optimal temp in about 5-10 minutes. It would also protect against over-cooling as the air-cooled ones may sometimes do. And yes, water-cooled.
EDIT: I should also mention I had a Koyorad Radiator and a Mishimoto Thermostat.
Mirageo (08-31-2016)
Old 08-31-2016, 11:35 PM   #10
Mirageo
Drives: Subaru BRZ
What aftermarket radiator were you running??
Old 09-01-2016, 10:50 PM   #11
ZeroTo86
ZeroTo86's Avatar
Koyorad.
CUSCO Vertical Catch Can & Oil Cooler w/ FREE Pre-Cut Samco Radiator Hoses! ZeroTo86 Engine, Exhaust, Bolt-Ons 3 08-12-2016 02:14 AM
OEM Radiator/Hoses For Sale! R3AP3R_Playz Engine, Exhaust, Bolt-Ons 3 06-29-2016 12:01 PM
New Release - Samco New Colors - Radiator, Heater, and Intake Hoses. FT-86 SpeedFactory Engine, Exhaust, Transmission 1 08-26-2015 11:48 AM
Koyo radiator, Venair hoses, Perrin oil cooler & pulleys, HKS inlet duct, G*S gaskets Turbowned Engine, Exhaust, Bolt-Ons 20 07-24-2015 11:59 AM
FS: Perrin radiator hoses ramiram1984 Engine, Exhaust, Bolt-Ons 6 03-25-2015 05:15 PM
