Old 08-15-2016, 02:44 PM   #1
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
Scion FR-S Steering Problems
Hey everyone, I have a 2013 FR-S that I bought brand new way back in 2012. I have done quite a bit of modifications to it over the last 4 years and have been able to quickly diagnose and fix any problems I have experienced along the way. I haven't driven my car a whole lot this year but the times I have driven it, I notice that the steering doesn't feel like it used to. We all know how the car feels when giving steering input. My problem is that now, the car feels almost unpredictable when giving input (I drive backroads frequently and reach speeds of 80+ in corners). It's almost "laggy" if I can describe it that way.
So, when I am entering a corner and start to turn, it's like I can physically feel all the parts in the car turning, but then the actual car itself follows afterwards, instead of immediately. When I swerve back and forth I feel the parts moving but the car sways behind that input, somewhat how older cars feel when you just turn the wheel back and forth while driving, but with more of a pull to it.
Also, when hitting higher highway speeds (75-80+) the car wants to wander around the lane slightly, and definitely is very noticeable at 120+. I have never been iffy about taking my car up to that speed, but now it just does not feel safe. I am certain something is wrong with my car, but I just don't know what it could be.
I thought maybe it something in the suspension or tires at first. I checked all tire pressures and they are fine (EDIT: Tires are Hankook V12 Evo2's and have less than 3k miles on them). I am running BC type BR coilovers and I checked them out and they seem to be fine. Sway bar end-links were all tight.
Next thought is possibly alignment or something physically wrong with the steering system?
Any input on this would be much appreciated. Thanks!
IG: @dustin_faulkner
Kuzuri is offline   Reply With Quote
Old 08-15-2016, 02:50 PM   #2
Trust86
Drives: 2016 Halo FRS
Bushings?
Trust86 is offline   Reply With Quote
Old 08-15-2016, 03:07 PM   #3
FTA_Dave
Drives: 2013 Frs, E46 Bmw
My first thought would be blown struts. Have you checked for oil leaks around the coil overs? Take the car in for an alignment check, explain what you are feeling and have them check over the suspension thoroughly. Sometimes it's easier to spot the issue with the car on the drive on hoist at ride height. On a side note, what trunk spoiler are you running ? It looks sick!
FTA_Dave is offline   Reply With Quote
Old 08-15-2016, 06:51 PM   #4
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Someone else mentioned similar strange feelings running the same tires: www.ft86club.com/forums/showthread.php?t=107534
So, tires maybe?
Originally Posted by humfrz
I'm old and lazy
Old 08-15-2016, 07:21 PM   #5
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
I have the exact same symptoms after changing to the Hankook v12s, I'm positive that they are the culprit. I'm trying to get rid of these as soon as possible, I'm around 3-4k miles on them also.
http://www.ft86club.com/forums/showthread.php?t=107534
Edit: ^^ Whoops, hey thats me! haha
Spacemane969 is offline   Reply With Quote
Old 08-15-2016, 07:31 PM   #6
humfrz
Hi ya,Kuzuri ............
Good looking machine you have there.
80 mph on Wisconsin backroads ...... I hope you don't catch a deer ......
What's wrong with your car?
Maybe waaaaay too much camber ......
You might try upping the pressure in the tires about 5 psi, to see if that reduces the squeaminish.
Like mentioned, it may be time for a good front end check up ...... before you toss the tires .....
humfrz
Old 08-16-2016, 06:29 AM   #7
DasFrs
Drives: 2013 Firestorm Red FRS
Where are you in wisconsin that you have actual corners?
Looking for more places to go other than Spring Green..
DasFrs is offline   Reply With Quote
Old 08-16-2016, 06:59 AM   #8
swarb
Jack up the car and try to move the wheel to see if there is any play. Possibly tie rods, or the soft sidewall hankooks.
Any changes since it last felt ok?
BTW what over fenders are those?
Old 08-16-2016, 07:07 AM   #9
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
No input on problem, just sayin
Sharp car!
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 08-16-2016, 08:33 AM   #10
extrashaky
Drives: 2014 BRZ Limited
I recently went from the stock rims and tires to 18x9.5 rims with PSS tires and immediately had the same result. The wider front rims and tires killed the feel of the steering and made it mushy. I had read that it would affect it, but it affected it a lot more than I was expecting.
Old 08-16-2016, 08:37 AM   #11
KendallH
Drives: 2013 FR-S Base, 1997 Jeep Wrangler
Wide tires and camber. Also this is in the wrong section.
KendallH is offline   Reply With Quote
Old 08-16-2016, 11:14 AM   #12
Hot-Lava_Dave
Hot-Lava_Dave's Avatar
Drives: 2016 Hot Lava MT
Does your car possibly fall into that recent recall for power steering?
Hot-Lava_Dave is offline   Reply With Quote
Old 08-16-2016, 11:20 AM   #13
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Odd. I have 17x9 wheels and 245 PSS. No mushiness at all, in fact, the opposite due to the PSS' stiff sidewalls.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
MarkR171 is offline   Reply With Quote
Old 08-16-2016, 02:31 PM   #14
Kuzuri
__(X)__
Kuzuri's Avatar
Originally Posted by Trust86 View Post
Bushings?
I can look into this.
The coilovers seem fine. I checked them for oil and loose bolts when I had the car jacked up. I mean I guess it's still possible. I have about 40k on the suspension. The spoiler is the Speedhunters KM4SH piece. Thanks!
So, tires maybe?
I have been feeling like the tires might be the cause. I have been running the same size Evo 1's for 3 years on the same size wheels and never had a problem. I didnt drive my car hard this year before getting new tires so I cant say for sure that the issue wasn't there before switching to the Evo2's but I definitely have noticed it since switching.
Do you think Hankook would do anything for us if we brought a few people to their attention that are experiencing these issues with the same tire?
humfrz
Definitely not my camber. I have had the same set up for 3 years without a problem. My car has done drift days, drag strip passes, and general hooning and runs on the backroads. This problem is very recent and unrelated to the fitment of my wheels. I added an extra 5 psi to the tires when I checked them and it didn't help. Thank you for the suggestion though!
I live in Boscobel, so you're not too far. Spring Green isn't a bad area though. You can head out towards Lone Rock/Avoca and hit that road that goes next to the River, or you could go out to Gotham and cut over to Muscoda. The road I am talking about that I hit 80mph through corners runs between Woodman and Prairie Du Chien. The first half is kind of rough but the second half you can really fly through the corners.
I tried this and didn't notice anything wrong. The only physical change from when it felt okay has been tires. I'm just not sure if maybe a certain bump could have knocked something out o maybe the coilovers have just gone bad
The over fenders are from Garage Vary. Very subtle but add a little bit extra. I'm happy with them for now!
Sharp car!
Thank you!
You have mushy response from wider front wheels? That's odd. I have run a square setup the entire time I've had the car and found the opposite to be true. My car is snappy and has quick turn in and sometimes gets a little too squirrely when sliding.
I didn't know there was one? More info?
The Following 2 Users Say Thank You to Kuzuri For This Useful Post:
DasFrs (08-17-2016), humfrz (08-16-2016)
scion frs oft problems please help Ethan Wagner Scion FR-S / Toyota 86 GT86 General Forum 31 03-26-2019 04:18 PM
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-04-2016 11:18 PM
[Power Steering/Electrical/Warranty] Problems, could use some advice. Ajax969 Issues | Warranty | Recalls / TSB 7 07-26-2015 07:01 PM
Dealer/Scion problems rucfj159 Scion FR-S / Toyota 86 GT86 General Forum 34 03-19-2015 09:24 PM
Shiny looking steering wheel problems... PrinzJ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 09-21-2012 10:08 AM
