Drives: 2013 Raven FR-S 6MT
E-Brake Boot Loose
I noticed today that my E-Brake boot wasn't in its slot properly, so I had to readjust it. No problem. I got home and pulled my E-Brake and the boot came out of the slots again. Has anyone else had this issue? If so anyone found a solution?
It only happens when I pull the E-brake in one motion instead of slowly pulling it up. |
i furiously yank up and down on my handbrake constantly so yes i've had a similar issue if not worse
the only solution i found is to use armor all to make the handle slippery for less friction |
#3 | |
Now to test to see if it worked! |
Drives: 2018 Golf R
Mine has done this since new. The stock boot is too tight. When you pull the ebrake up, the tension on the boot pulls the frame up and out of the slots in the center console.
I just push it back in every time...
Parting out HERE
| AP Racing Brake Kit - Loose Pads Rattling Inside Calipers | MINOCIN | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 07-07-2016 03:40 PM |
| FS: OEM Cluster Hood / Shift Boot / E-Brake Boot | zeal86 | Interior Parts (Incl. Lighting) | 7 | 07-03-2016 11:48 PM |
| FS: OEM BRZ Shift boot and E-Brake boot SOLD | johnb831 | Interior Parts (Incl. Lighting) | 1 | 02-09-2015 06:37 PM |
| clicky/loose brake pedal? | nyfries | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 08-26-2014 10:59 PM |
| FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
