Old 08-09-2016, 02:27 PM   #1
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
<FS> P2M front tie rod set (inner/outer) $150 shipped
Selling used set of inner/outer tie rod/tie rod ends for FRS/BRZ.
Outer is pillowball w/ a collar that you can remove or move up, to adjust bump steer.
Inner has an additional collar built in to the end where it meets steering rack. The purpose of this is to give the driver more steering angle, especially for drifting.
I used this setup for approx. 10 months. There were no major drawbacks, I drove with it fine at the track, however when using it on streets the default traction control had a tendency to kick in aggressively when I turned in sharply. It kicked in pretty aggressive when I come off freeway offramps and brake/turn at the same time, sort of an aggressive trailbraking situation.
If you have a habit of turning off traction control, this isn't an issue.
Asking $150 shipped in CONTUS. PM me for more info.
-alex
Old 12-19-2017, 12:01 AM   #2
DR_brz
Drives: lighting red BRZ
Sooooo I know this is over a year old...but available?
DR_brz is offline   Reply With Quote
<FS> Raceseng Tug View tow hook rear $100 shipped UPM $100 shipped mav1178 Exterior Parts (Aero, Lighting, Etc.) 7 08-11-2016 02:03 PM
Password JDM Canards Outer TomT2411 Cosmetic Modification (Interior/Exterior/Lighting) 1 10-17-2014 06:43 PM
Longer inner / outer tie rods than oem? PradiG Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-05-2014 08:19 PM
SOLD*** Password JDM Inner AND Outer Canards bear89103 Exterior Parts (Aero, Lighting, Etc.) 5 01-03-2014 11:39 AM
Outer tire wear at track? fasteddy Tracking / Autocross / HPDE / Drifting 20 07-24-2012 01:16 PM
