| Off-Topic Lounge [WARNING: NO POLITICS] For all off-topic discussion topics. |
Rambling Man
Drives: 2013 FR-S 6MT - In Heaven Now
My Car Is (Almost) Out Of Timeout!!!
Car is fixed!!!! I just need to go down and get tires mounted/balanced to bring them back to the shop to put them on, then I'm back in the saddle again!!!
#FiftyShadesOfBlue
Drives: 2015 FR-S
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes ![]() |
| The Following User Says Thank You to Tectoniic For This Useful Post: | FNCrazy (08-05-2016) |
Rambling Man
We have rebuilt it. We have the technology. It is even better than before.
I will therefore not drive over 15.7MPH inside any city municipality to not have to go through this again. |
#FiftyShadesOfBlue
Drives: 2015 FR-S
too lazy to find original thread....what happened to it?
Rambling Man
Some people say I'm the worst driver in the world who only blames his tires. Hmmm...Even though I specifically said it was NOT the tires fault, I was inattentive and ran out of talent. Tires were pretty well on their last leg, and with fresh rubber, maybe, just maybe I would have pulled it out, but probably not.
I've had it a month (it's a 2013). I came around a decreasing radius corner without paying too much attention to how much it was decreasing, too fast, no traction control on (except the pedal dance), it oversteered a bit, which was fine (fun), but then I get a bit hazy. I was going about 60mph, I countersteered like normal (I thought), but then it snapped oversteer the other way and I went twirling down the road. Luckily no traffic in the way and a wide road. Before I could get stopped, I hit the opposite curb completely square with the passenger side. Destroyed my passenger rear suspension, rear um...brace (?) that holds everything together between the frame rails, two tires, wheels, brake lines, a bunch of other odds and ends. So, I upgraded just a couple things. Stainless brake lines so hopefully they won't get cut again (not that it was that big of a deal, but I got a good deal so why not?). Rear aftermarket LCA's, not much else aftermarket. I did have a stockpile of aftermarket parts I was waiting (lazy) to install, so I had them do that too, including RCE springs. Oh, and I got two new OEM wheels because I couldn't decide on anything better, but did get 4 new Pilot Super Sport's. So, completely my fault, but I learned from it. And I always love putting it on forums because all the perfect drivers out there then berate you on what an idiot you were! Uh, duh! My checkbook helped me determine I was an idiot long before I posted!
Dude! You do not need to start a new thread every time a stray thought passes through your mind. There is room in Random for one more.
| The Following User Says Thank You to Tcoat For This Useful Post: | Cole (08-06-2016) |
Rambling Man
Tires are still in jail unfortunately. Tire shop didn't have time to mount and install them, so I get to see what the Prius ones were like (on loan). Not as bad as I thought they might be.
#10 |
Hey! Between us we have 1 full set of oem rear suspension parts! Seriously though, if I'd seen your thread I would have tried to sell you my parts. I smashed the driver side and replaced LCA, toe, and trailing arms. So I have the passengers in a box in the garage
| The Following User Says Thank You to Ashikabi For This Useful Post: | FNCrazy (08-08-2016) |
#11 | |
Rambling Man
Mine unfortunately included the crossmember thing that the suspension for each side sat on, so the damage didn't really want to stay on it's own side
#12 |
The sub frame? Mine has a bent bracket but with all adjustable arms I just worked around it
#13 |
Rambling Man
#14 | |
Last Starfighter
Drives: 2016 FR-S Series 2.0
