Old 08-05-2016, 12:33 AM   #1
owenxguo
owenxguo's Avatar
Drives: MY13 BRZ
Power steering C1528 code
My car is track only car, and I'v had issue turning after lowering and use grip tires. In motorsport section people suggest raise the car, which I have tried, but still not working. Then during last event I found out that when you lower the car too much(and my tires are bigger than original), I see signs of the wheels rub the lower part of the strut tower(frame), which I think that's where this problem came from.
Somehow when my guys took my car to a car show, the power steering start malfunction randoms, pulled a code of C1528, steering motor angle sensor.
Does anyone knows what might cause this problem? I am guessing it's because when the wheel hit the frame and can't turning, but you force to turn the car, something wrong in the steering motor might damage, but this is random but not happen all the time.
Thanks
owenxguo is offline   Reply With Quote
Old 08-05-2016, 08:31 AM   #2
Ashikabi
Ashikabi's Avatar
I don't know what exactly the code is for but the power steering may have just "lost home" or be out of position. Did you try pulling the battery too attempt to reset it? Otherwise might have to pull it apart and reposition the sensor(or something)
Old 08-05-2016, 01:30 PM   #3
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
http://www.news.com.au/finance/busin...da0f6c034f5478
Power Steering rosol16 Issues | Warranty | Recalls / TSB 15 12-15-2015 09:44 AM
Where is our power steering ECU? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-24-2015 12:38 PM
WTB Power Steering motor boostedfrs Want-To-Buy Requests 0 04-08-2015 11:19 AM
power steering ender2664 Engine, Exhaust, Transmission 32 03-21-2015 04:16 PM
Electronic power steering Mathewgzlz Issues | Warranty | Recalls / TSB 9 01-22-2014 01:50 AM
