Old 08-03-2016, 10:41 PM   #1
Shady195
Drives: '13 10 Series FRS #1203
Toe Rods with Heim joints making noise?
I just installed PBM's toe rods on the rear of my car, the previous set I had were very inferior and a few months of driving they were squeaking awfully loud and upon taking them apart they were rusted.
Anyways, I decided to pick up a set a PBM's to try, however it seems now that whenever I go over a bump, especially when one side moves more, i get a pop, almost like something is hitting. Everything is tight, and it looks like when sitting in my driveway that the toe rods are a bit crooked and very close to touching the sides of the rod (where the reaches its outward most movement)
Shady195 is offline   Reply With Quote
Old 08-04-2016, 07:34 AM   #2
wparsons
wparsons's Avatar
Is there any play in the heim joints at all?
flickr
Old 08-04-2016, 04:08 PM   #3
Shady195
No they seem solid, but I may have just figured out what it was..
The PBM toe rods are pretty bulky, more so on one side where the threadded slip joints clamp, I have a suspicion they are hitting the traction rods.
I'll see about it when I get home.
The Following User Says Thank You to Shady195 For This Useful Post:
Sleepless (08-05-2016)
Old 08-05-2016, 09:42 AM   #4
frslee
Just drive it
Drives: 13' FR-S
Don't heim joints make noise? I remember having upper control arms in full heim joints in my previous car and it made noise when going over bump. All bolts were tight and solid. So I ended up getting 1 side heim joint and other end factory style bushing and it didn't make noise since then.
frslee is offline   Reply With Quote
Old 08-05-2016, 01:40 PM   #5
strat61caster
strat61caster's Avatar
Not if they are working properly, they just transmit all the vibration and motion from the wheel to the chassis so the noise you feel is increased.
Ones that are low quality or worn out will make noise.
ineedyourdiddly
Old 08-05-2016, 02:38 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
For the record, heim joint = ball joint = tie rod end (both inner and outer). If it makes any noise, change ASAP. That hammering will eventually result in a catastrophic fatigue failure.
K Sports making noise? Brentkeys1814 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-22-2016 06:24 PM
Buddy Club Racing Spec Damper, Buddy Club Ball Joints, Megan Extended Tie Rods, etc Chase Bays Brakes, Suspension, Chassis 14 02-03-2016 09:14 PM
kw v3 rear making clunking noise eera Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-17-2015 04:10 PM
New rims and tires making a noise Frs32907 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 08-21-2013 03:01 PM
Ballast Making Noise remorse87 Cosmetic Modification (Interior/Exterior/Lighting) 7 10-24-2012 10:35 PM
