Old 08-03-2016, 12:31 PM   #1
GT86Dan
GT86Dan's Avatar
Drives: 2013 scion frs
Ark Design Exhaust Review
Came across the company via the forum here. After about a week of emailing back and forth (which all emails were responded to very quickly) i finally pulled the trigger.
It showed up in about a week.
Packaging Exhaust came in a nice large box, with the ark design logo right on the front. Box was stapled and then wrapped in the plastic tie downs. Inside tons of foam and bubble wrap, and everything was taped. The tip even was covered with a cardboard cylinder and more bubble wrap. Even came with some hardware and a sticker !!!! WOOO !! +5hp here we come !!
Welds/Workmanship So i am by no means a welder. All welds look great though and very well done. No problem areas that i can see anywhere. The exhaust has the logo engraved on the tip, and has a tacked on serial number plate on the back side.
Fitment Coming Soon !
Sound Coming soon !
Overall so far i am very impressed. I have a very sneaky suspicion that this exhaust is made in the same factory that tomei and gruppe s is. Also made in Taiwan. Welds even look the same !
Should have this mounted up by weeks end. Will be pairing it to a gruppe s uel, tanabe overpipe and stock front pipe. Will also be testing if it fits with the Velox rear diffuser, and their new exhaust cutout cover they just released. Should be fun times !!
Speed has never killed anyone, suddenly becoming stationary… that’s what gets you. – Jeremy Clarkson
GT86Dan is offline   Reply With Quote
Old 08-03-2016, 12:32 PM   #2
GT86Dan
GT86Dan's Avatar
more pics
Old 08-03-2016, 03:06 PM   #3
ModinJapan
ModinJapan's Avatar
Drives: 2013 SCION FRS
Originally Posted by GT86Dan View Post
more pics
Work of art isn't she
Thank you for posting and looking forward to the product on your car with sound clips
ModinJapan is offline   Reply With Quote
Old 08-03-2016, 03:52 PM   #4
exE36M3
subscribed for sound. I'm debating the sound/drove issue. Just needs to be tolerable at highway speeds.
exE36M3 is offline   Reply With Quote
Old 08-03-2016, 05:56 PM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Found this video [ame="https://www.youtube.com/watch?v=B7dRp4O2Sc0"]ARK Design Racing Spec Exhaust for Scion FR-S / Toyota FT-86 / Subaru BRZ (Single Outlet) - YouTube[/ame]
Nice that the piping is 2.5" versus the 3" on the Greddy and HKS single exit models, should help the sound be a little more reasonable for DD.
Originally Posted by humfrz
I'm old and lazy
Old 08-04-2016, 05:05 PM   #6
ModinJapan
ModinJapan's Avatar
http://www.motoiq.com/MagazineArticl...c-Exhaust.aspx
Check it out. Great write up
Old 08-05-2016, 12:09 PM   #7
GT86Dan
GT86Dan's Avatar
Update !!
Just installed the exhaust yesterday. Install went without any major issue.
Fitment Exhaust fit like a glove. No issues whatsoever. Piping is nice and tucked against the body and sits flush. The only issue that we had is with the Velox rear diffuser. The piping route swoops hard to the passenger side and the diffuser exhaust opening just was not big enough. Easy fix though as we just cut to accommodate the new route. Bolted everything back up and solid as when i first received it.
Sound Coming from a cracked Dezod catback this one sounds very tame under 3k rpm It truly is a quality exhaust, having more of a guttural tone if that makes sense. Drone is nearly non existent. Driving around normally and cruising you almost forget its there. Until you put your foot down and the 4 horsemen of the apocalypse come charging out. Nice and loud but not annoying in any way. Very clean sounding, with the occasional downshift pop and gurgle It also passed the girlfriend test
Final thoughts Overall i am extremely happy with the exhaust. I think Ark Design made a fantastic product and everyone should look into them. The exhaust is still brandy new so looking to add a long term review to this thread. Hopefully ill have no surprises like the last pile of tubing i had. I have a track day coming this next week and will have more footage as the week goes on
[ame="https://www.youtube.com/watch?v=RaRtXJ707F4"]https://www.youtube.com/watch?v=RaRtXJ707F4[/ame]
Old 08-05-2016, 12:33 PM   #8
ModinJapan
ModinJapan's Avatar
great write up.
May i suggest adding washers on your diffuser to add clearance
Old 08-09-2016, 06:33 PM   #9
ModinJapan
ModinJapan's Avatar
any other sound clips yet?
Old 08-11-2016, 05:11 PM   #10
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
In other news, @GT86Dan s girlfriend is deaf!! Just kidding, but I'm not familiar with any other N1 style exhausts that pass the GF test.
Could we have a few soundclips of it revving out? Cold start is often loud, and idle is often quiet, so I'm hoping for some cruising and higher rpm's.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 08-11-2016, 05:36 PM   #11
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Still on my quest for a single exit exhaust option. My main concern is drone at highways speeds around the 60~70mph range. I'm not overly concerned about acceleration, just cruising. Any comments on this? Thanks for posting up.
JimmyMac is offline   Reply With Quote
Old 08-11-2016, 06:45 PM   #12
ModinJapan
ModinJapan's Avatar
One thing i know about the ark design brand.(yes i have the racing spec on my FRS). Its one of the least amount of drone from any other one's i've sat in
but if you have UL HEADERS, overpipe and non res front pipe, its always going to be louder
Old 08-11-2016, 11:23 PM   #13
GT86Dan
GT86Dan's Avatar
Heres a fly by from my track day yesterday. Going to get a full exhaust vid soon. Cold starts, idle , interior , acceleration. Just give me the weekend. After having it on a week now, at highway speeds there is no drone even with uel.
[ame="http://https://www.youtube.com/watch?v=t8TmMyzrC-c&feature=share"]http://https://www.youtube.com/watch?v=t8TmMyzrC-c&feature=share[/ame]
Old 08-12-2016, 12:06 AM   #14
ModinJapan
ModinJapan's Avatar
wow that sounds amazing. and at WOT, its was not obnoxious
JDL Auto Design - 2014 Exhaust Products JDLAutoDesign Engine, Exhaust, Transmission 1648 03-28-2018 09:53 AM
Review: Pro Street Coilovers from Speed By Design ericmpena Suspension | Chassis | Brakes -- Sponsored by 949 Racing 67 03-08-2015 12:00 AM
Exhaust muffler design/placement vs mpg vtmike Engine, Exhaust, Transmission 7 02-10-2013 01:01 PM
Perrin Pulley review? Invidia Q300 exhaust review? ScionFrsFan Engine, Exhaust, Transmission 4 12-10-2012 08:27 PM
FRS Design Review russv Scion FR-S / Toyota 86 GT86 General Forum 44 09-27-2012 07:02 PM
