Old 07-28-2016, 02:38 AM   #1
cammyT
Drives: 2015 Scion FR-S
Texas 86ers: Help needed with manual trans measurements
Hello Texas 86ers!
I'm having some custom clutch parts made and in order to move forward with where I'm at in the process, I to take measurements inside of the bell housing of the manual transmission as well as the distance between the clutch fingers and engine block.
Unfortunately, I don't have the ability to take these measurements on my own car at this time since it's my DD and in use every day.
Does anyone on here who stays in Texas have any of the following:
engine and transmission (not bolted to each outher - also out of car)?
car with transmission uninstalled (engine still intact)?
Plan to do clutch removal/install in the near future?
Any combination or subset of above scenarios?
If so, would I be able to come by and take the above mentioned measurements? It would be amazing and a huge lift I could this!! I'm local to Austin but am willing to drive to to different cities if that what it takes.
Can anyone help with this??
cammyT is offline   Reply With Quote
BRZ/FRS AZ6 Manual Trans Upgraded Gearset RockySDS Engine, Exhaust, Transmission 169 09-15-2022 08:55 PM
FRS/BRZ Manual Trans Fluid shellslinger Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 131 11-02-2017 10:44 AM
Manual Trans 12k miles $750 OBO Amir Ghadiri Transmission and Driveline 4 05-23-2015 02:35 PM
Manual Trans (Reverse Issue) mxrcmxlendon Engine, Exhaust, Transmission 1 02-24-2014 11:18 PM
Bump start in a manual trans? bayank BRZ First-Gen (2012+) — General Topics 11 02-16-2014 06:47 PM
