Old 07-27-2016, 09:01 PM   #1
Xplicit
5 axis R5:F rims with spacers???
Hey there, I own a 5axis edition frs and I'm wondering whether or not the r5:f 19 inch rims can use spacers without needing to custom fit them. I'm curious because I'd like to add a 15/16mm spacers to the rear tires.
Xplicit is offline   Reply With Quote
Old 07-27-2016, 09:42 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
I would recommend you do a bit of reading on wheel sizes and offsets.
There is zero reason why you need wheel spacers ever.
I highly recommend people buy wheels with the right offset to achieve their preferred look.
Go spend some time in the wheel and tire section and read. Drop some knowledge into your brain.
Old 07-27-2016, 09:48 PM   #3
Xplicit
Well my car is already lowered from factory as it was a limited edition model made for scion employees -- it has the lowering springs and entire five axis kit. I just wanted my rear tires to stick out a tiny bit socks they aren't staggered, to make it look better and add some grip on the back end (a bit least sideways ass out play)
Old 07-27-2016, 10:45 PM   #4
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Offsets doesn't get you better grip.
Tires get you better grip.
You can have skinny ass 6" wide wheels, but with some r-comps or simi slick tires they will out grip a 10" wide wheel on all season OEM tires.
You can get wider sticky tires.
First of all what offsets do those wheels have? Find that out first.
If your dead set on spacers start with wheel info. Then see how much studs length you have to play with. Chances are your studs are not long enough, so you'll need those bolt on hub wheel spacers.
Old 07-27-2016, 11:27 PM   #5
Xplicit
Primarily, it would help the look of the car a ton - especially mine. I'm running 19" by 8.5 on low pro tires and I am leaning towards bolt ons for that reason
Old 07-27-2016, 11:54 PM   #6
[YOYO]
Amazing Member
[YOYO]'s Avatar
Drives: 2014 Whiteout FR-S
A quick search on the forum brings this up -
http://www.ft86club.com/forums/showthread.php?t=14234
The offset is +45. Unless you are planning on running negative camber, or want to go all herra frush, you won't need any spacers. The wheels look fine without them in those pics. They were made with a modestly lowered (on Eibach springs) FR-S in mind after all. Hope that helps.
MY 86 BUILD
[YOYO] is offline   Reply With Quote
Old 07-28-2016, 04:17 AM   #7
Xplicit
Those aren't my set. I'm running the R5:F's
Not looking into negative camber or angling my wheels. Just want the rear tires to come out slightly further than my front.
Old 07-28-2016, 04:20 AM   #8
Xplicit
Old 07-28-2016, 05:32 AM   #9
machewcoy
machewcoy's Avatar
Drives: 2014 Raven FRS
After some quick Google-ing, the RS:F wheels do have a +45 offset as well, so it's the same in that regard. And, again, after looking at some pics of the 5Axis FRS with the RS:F wheels, the wheel fitment already seems to be on point, so you don't really need to run spacers. But, if you really wanted to flush out the fitment even more, I guess you could go with a super tiny spacer, like a 5mm? You may need to roll your fenders, though, because the RS:F is a big wheel, and it looks like it doesn't have much room to play around with.
Hope that helps!
machewcoy is offline   Reply With Quote
Old 07-29-2016, 10:26 PM   #10
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
From my quick google-Fu I found there are two possible offsets, 45 and 35.
Not sure which one you got look at the stamps on the back of the wheel for the info.
five axis, rims, spacers
Spacers and rims combo daironchef Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 03-20-2016 08:59 AM
help with spacers to clear ap sprint kit with stock rims didinyc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 11-23-2014 01:27 PM
Spacers with RCE Yellows on Stock Rims/Tires? husker741 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 05-04-2013 04:21 AM
Which Five Axis S5:F Rims? Which Offset? sharkasport AUSTRALIA 8 12-11-2012 12:21 AM
Five-Axis rims? blackknight.ktn Scion FR-S / Toyota 86 GT86 General Forum 9 11-29-2011 03:23 PM
