CANADA Canada
Old 07-26-2016, 04:33 PM   #1
alanhung85
Drives: 2014 Subaru BRZ Sport-tech Pkg
End of Lease Buy Out: Do I need the stock parts?
I am thinking of buying out my leased vehicle at the end of the lease. I understand in order for the ownership to transfer (ownership currently says Toyota Credit), I will need an safety certification (emissions?) done.
My car is currently riding on aftermarket springs and wheels. Do I need to convert the vehicle back to stock form if I am buying the car out at the end of my lease? I do not intend to put any parts on that will mess with the emissions or render the car "unsafe" to drive but I rather not waste time / money putting on aftermarket parts then having to convert back to stock just for the transaction process at the end of my lease.
Anyone with knowledge or experience they can share?
alanhung85 is offline   Reply With Quote
Old 07-26-2016, 04:47 PM   #2
DAEMANO
Time Traveller
Don't know if the laws are the same in Canada. In the U.S. it makes no difference at all if you have springs on the car and buy out your lease. Transfer of title might require a smog check which means you gotta put your stock emissions related parts / ECU tune back on.
Old 07-26-2016, 05:11 PM   #3
btune
btune's Avatar
I just bought out my leased BRZ last month.
You'll need to get your car safetied (~$60-$100). Emissions wasn't required. I don't think it's required until your car hits a certain age.
The car doesn't have to be in stock condition to buy-out (I had coilovers on mine).
btune is offline   Reply With Quote
The Following User Says Thank You to btune For This Useful Post:
Mr.Impreza (07-26-2016)
Old 07-26-2016, 05:13 PM   #4
alanhung85
Thank you for your response gentlemen. That puts my mind at ease. Time to get some coils and wheels!
Old 07-26-2016, 06:05 PM   #5
Noxcyn
Noxcyn's Avatar
Drives: '15 Scion FR-S - Ashphalt (MT)
Emissions is once the car is 7 years old then every other year after that.
Noxcyn is offline   Reply With Quote
Old 07-26-2016, 06:15 PM   #6
jamies31
jamies31's Avatar
Drives: 2014 Scion Frs (Argento)
i would highly suggest doing a little research on the shop before you go in for the safety. with new safety rules as of july ist some shops may deam that non oem components. as stupid as these new rules are
jamies31 is offline   Reply With Quote
Old 07-26-2016, 06:15 PM   #7
jamies31
jamies31's Avatar
and you will need emissions even though its not older than 7 years the ownershipis changing hands which requires a emmissions test
Old 07-26-2016, 08:35 PM   #8
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
One major hiccup you may want to research about: As of July 1, Ontario has enacted more stringent safety standards for used cars.
Apparently, even minor things like oil consumption or fluid leaks will be flagged for repair.
I would see if you can find a garage which is friendly toward sports cars or modded cars (iGarage comes to mind) and ask for advice.
daiheadjai is offline   Reply With Quote
Old 07-26-2016, 09:26 PM   #9
alanhung85
Thank you for the feedback. IGarage is my goto shop. Great shop and great service!
Old 07-27-2016, 06:55 AM   #10
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
If he needs emissions it won't be a problem anyway.
The Following User Says Thank You to guybo For This Useful Post:
wparsons (07-27-2016)
Old 07-27-2016, 03:09 PM   #11
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
You never know. I've worked at dealerships, and I've seen "brand new" cars not pass emissions.
However assuming you don't have a CEL you'll more than likely be fine.
Speaking of e-tests though, does anybody know how thorough most places are? I have a catless front pipe, and It would be a hassle to have to put the OEM one back on.
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 07-27-2016, 04:50 PM   #12
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
It depends on the shop. My sister just took her car to Oil Changers for e-test and all they did was plug in the reader. Of course, her car is a stock Kia Forte and gives no reason for a second glance. If you are driving something clearly modified or unusually loud, then they might do a visual check for cats which is where you'll get burned.
Lynxis is offline   Reply With Quote
Old 07-28-2016, 09:31 PM   #13
DSKIRROW
Drives: 2016 Scion FR-S
I live in B.C. and here they don't care what you've done to it if you're buying it out. You can even go into the dealership without the car and do it. In the Vancouver area you need an emissions check every few years for insurance but unless your car is putting out a ton of pollution you'll be fine. Not sure about the variance in other provinces though.
DSKIRROW is offline   Reply With Quote
WTB: Stock Intake, Stock Radiator, Black Front End Body Parts nmullin11 Want-To-Buy Requests 0 06-14-2016 10:23 AM
Suspension parts: Whiteline bushings, stock strut parts, Turn in concepts steering FRSPirate Brakes, Suspension, Chassis 6 05-26-2016 04:30 PM
Really need ADVICE: Buy out LEASE? Or Lease New Car again? PoRco Scion FR-S / Toyota 86 GT86 General Forum 83 09-02-2015 07:15 PM
2013 Hot Lava FRS $23,860 or Lease for $406.80 Per 37 month Lease Employee Canada Classifieds 19 03-18-2014 10:34 PM
