Old 07-23-2016, 09:01 PM   #1
Visitor.S
Drives: Frs
how much psi on turbo dose frs need a bov
anyone knows how much psi on turbo dose frs need a bov?
since greddy turbo didnt come with a bov, i do some search that seems like under 300whp will not need for a bov but every over 400 have a bov,
anyone know how much psi should add a bov? thanks
Visitor.S is offline   Reply With Quote
Old 07-24-2016, 01:58 AM   #2
kev60625
Drives: 2013 WRB Subaru BRZ
I'm not really knowledgeable on this to be certain, but I'm pretty sure you can put a bov on any turbo...I'm guessing it comes with a bpv?
You should do some research..
I used to own a wrx and know stis/wrx's don't come with BOV, but bpv's. You can put a bov on any of them though, but from what I read, it wouldn't be the most ideal setup..
kev60625 is offline   Reply With Quote
Old 07-24-2016, 07:10 AM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
The only difference between a BOV and BPV is that a BOV (Blow Off Valve) bents to atmosphere whereas a BPV (By Pass Valve) vents to a recirc tube back into the intake. My GenCoupe came with a BPV but I deleted the recirc tube because it recirc'ed hot air (and I like the sound of a BOV).
Even a first gen GenCoupe 2.0T comes with a BPV even though it only makes something like 240 HP. A BOV/BPV protects the engine and turbo from getting damaged, it is needed on all turboed cars. The wastegate prevents further boost from being made, but it does nothing for boost that is already present when you go off-throttle. That's what the BOV/BPV does.
The Following 2 Users Say Thank You to guybo For This Useful Post:
Curtski96 (07-24-2016), humfrz (07-24-2016)
Old 07-25-2016, 10:33 AM   #4
FX86
5ml dose should work fine
The Following 2 Users Say Thank You to FX86 For This Useful Post:
COO86L (07-26-2016), STV3 (07-25-2016)
Old 07-25-2016, 10:35 AM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
How much PSI?
Theoretically any boosted engine should have some type of blowoff/bypass mechanism. It's there to prevent compressor surge, and really meant to protect the turbo.
If you retain the stock MAFS and have a BOV setup venting to the atmosphere, you need to make sure you have the proper tune to compensate for it, otherwise you may stall between shifts or have really poor throttle response due to rich mixture.
-alex
Old 07-25-2016, 11:20 AM   #6
scmil95eg
Drives: '95 delSol, '13 EvoX, '14 Leaf
Correct. In addition, it helps keep the turbo spooled between shifts by relieving the pressure on the compressor side.
If you're new to turbos, you absolutely need a wastegate, can't run without one. You can run without a BOV but you'll increase wear on your CHRA exponentially. Especially journal type CHRAs.
scmil95eg is offline   Reply With Quote
The Following User Says Thank You to scmil95eg For This Useful Post:
wparsons (07-25-2016)
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
FS: AVO turbo kit with upgrades / Drift Bar / Misc turbo parts Blanka Engine, Exhaust, Bolt-Ons 10 06-16-2016 03:02 PM
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
Bren5279's Full turbo partout (JDL uel turbo, Greddy Evo 3, AEM gauges, + More) VA bren5279 Engine, Exhaust, Bolt-Ons 69 06-29-2015 10:56 PM
