Old 07-23-2016, 11:34 AM   #1
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Return Style Fuel System Q&A
I've googled the hell out of this but with the GT86, BRZ, FRS I can't find anyone posting a return style fuel system layout map for using aftermarket billet rails.
I'm about to go Flex Fuel and I want to add a return style fuel system before doing so.
I do understand there is a kit but some things I like to do myself.
Noted, I plan on removing all the factory fuel rails leading to the engine as well.
Billet Rails, Layout 1
Billet Rails, Layout 2
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 07-23-2016, 04:46 PM   #2
FRS Justin
Drives: 2013 Asphalt FRS
I believe Radiums website has a return system how to on their website in the blog section. Also consider buying their stuff. I have never been disappointed with Radium its awesome stuff......
Also your diagram is off a little there is a much easier way. PM me
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 07-24-2016, 09:21 AM   #3
GsxrMe
GsxrMe's Avatar
I've contracted Radium support. It saddens me to only see a billet return style fuel pump hang for Impreza, Forester, Legacy & Outback but no BRZ/FRS.
2014 Subaru BRZ
Old 07-24-2016, 11:44 AM   #4
BRZFRSSTORE
Drives: 2013 brz
You will need to feed the primary rails first gong into secondary rails to regulator and then return to tank.
BRZFRSSTORE is offline   Reply With Quote
Old 07-24-2016, 12:19 PM   #5
FRS Justin
I just sent them my old fuel tank, they are building a system for the 86. Patience grasshopper.....
710whp
Old 07-24-2016, 12:32 PM   #6
FRS Justin
I just reread your post. If I were you I would leave the DI system alone....
Here is why, DI low pressure is 276psi then it will throw a code, target pressure is 581psi and the number one reason is high pressure to trip a stuck code is 2785psi..... Just give the high pressure DI pump a good constant fuel source and your golden... The DI injectors are not changing so the requirement will not change.....
710whp
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 06:21 AM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 03:52 PM
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
fuel return system? lbroskee Engine, Exhaust, Transmission 4 03-04-2014 06:56 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
