Old 07-21-2016, 04:45 AM   #1
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
Budget engine build
Hello people of the internet!!
Planning on doing a semi budget engine build. By that I mean, buying only what I need, not everything I can.
For instance, I doubt I'll be pushing near or past 500whp so I'm happy running Skunk2 Alpha or Brian Crower.
The main question is; do I neeeeeed forged pistons? I want stock CR and an easy build.
inb4 do it while the engine is apart. Everything will be done in house so that's not a valid excuse/reason.
Facts: 2015 Engine, 20,000 KM
Current purchase/wish list:
King or OEM bearings
ARP head and main studs
Rods TBC
Head Gasket TBC
Anyone with experience with these engines please pipe up and fill me in
Thanks in advance
COO86L is offline   Reply With Quote
Old 07-21-2016, 05:32 AM   #2
swarb
You should list your budget. And then double it. Any kind of proper build would be at least 10k(including turbo/fueling/supporting mods), probably closer to 15-20k. So don't even bother unless you are ready to drop that kind of cash.
You should mention your goals also.
I would just copy a build from a company or car and then go from there.
Cheap, fast, reliable. Pick two.
Old 07-21-2016, 05:36 AM   #3
COO86L
COO86L's Avatar
The oinly costs incurred will be parts. There is no building costs.
I already have the form of forced induction though I may change to turbo (currently looking at 18psi with sc) though I'd manufacture it in house.
Aim is as stated, under 500whp. Only supporting mod not purchased is any drive shafts that may break. And tires.
As stated above: there is NO labour costing. This will all be done in house. The only cost involved is parts.
Old 07-21-2016, 07:04 AM   #4
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
You need pistons.
Old 07-21-2016, 07:09 AM   #5
COO86L
COO86L's Avatar
Why for?
I'm thinking of having the crowns ceramic coated?
Old 07-21-2016, 01:56 PM   #6
swarb
We can't help you if you don't have specific budget or goals.
499hp then.
http://www.ft86club.com/forums/forumdisplay.php?f=78
Old 07-21-2016, 03:00 PM   #7
Lantana frs
Drives: 13 frs red
Cheap build = stock. Cryo, coatings etc. It can still blow up
Lantana frs is offline   Reply With Quote
Old 07-21-2016, 03:08 PM   #8
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I will throw my $0.02 (its Canadian so vs a US 2 cents its kinda worthless)
Do pistons and drop the CR to 10:1 if your planning on running more then 15psi boost. It will make tuning much easier.
Old 07-21-2016, 05:07 PM   #9
COO86L
COO86L's Avatar
I use the term budget to mean not spending more than necessary. There is no monetary limit because building an engine with a cost goal is stupid.
All I want to know is if pistons are essential to a build in this car and if so, why?
Old 07-21-2016, 05:46 PM   #10
FRS Justin
Drives: 2013 Asphalt FRS
Pauter rods, Outfront Motorsports Custom 12.5 piston made by CP, Stock headgasket. Supertech valvetrain......
Here's why, when you boost a motor you need to increase the ring gap, and possibly the piston clearance depending.. I would never try to push 3X more power on a stock piston. Pistons are cheap compared to doing it a second time....
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 07-21-2016, 06:21 PM   #11
COO86L
COO86L's Avatar
That's the second time I've been told that exact set up. Except I haven't really looked at valvetrain due to not planning to run any higher RPM or anything such. But I shall still look into it.
Thank you for an actually helpful reply
Old 07-21-2016, 09:35 PM   #12
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Every build needs to have an target, whether a monetary limit or an intended purpose. Right now, knowing only that you plan to target "less than 500 hp" is way too wide of a scope to give you proper advise. Vastly different planning is needed if you were trying to hit 500 as opposed to 300. It also matters if this is a DD/street/drag/track car. Without that sort of basic info, the word "need" doesn't mean anything because nobody knows what that means.
Doing a build with stock pistons is generally regarded as somewhat pointless, because regardless you have to get new rings and deglaze the block whether or not you change the pistons.
You can consider everything done in house and discount labor costs, but if it needs to be done twice, you're still doing it twice and you're paying with time.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 07-21-2016, 09:53 PM   #13
FRS Justin
If you boost and rev you need the upgraded valve springs.... The reason is the extra pressure on top of the valve will float a stock valve during high rpm sure your safe at 7 psi but 500hp will not happen pushing 7 psi
710whp
Old 07-21-2016, 09:59 PM   #14
COO86L
COO86L's Avatar
Thank you for the legitimately helpful people here. I momentarily thought you'd all died out
We just have zero experience with this engine, it's a building ADVENTUREEEE! Infact we are probably going to buy and build a second engine just because.
Just gotta wait for the R32 GTR engine to be finished
Thanks helpful people! I know deep down I'm just being lazy and looking for reason to justify my laziness
College Budget Build jaorocks1 Member's Car Journals 26 05-04-2016 06:43 PM
Critique My Budget Build Wolfdogelite Electronics | Audio | NAV | Infotainment 10 04-05-2015 02:27 PM
Budget stereo build toast Electronics | Audio | NAV | Infotainment 4 12-17-2014 04:10 PM
My boosted build...on a budget PineappleFriedRice Member's Car Journals 95 08-17-2014 09:29 PM
Aznsky's budget STX build Aznsky Tracking / Autocross / HPDE / Drifting 13 05-12-2014 08:44 AM
