Drives: Raven Fr-S
What would be needed to run at 8500 RPM?
I read through the Element tuning thread but that engine was running a lot of boost at 9000 rpm.
Assuming the tune takes the raised rpm into account, is the stock engine assembly capable of handling an 8500 rpm redline? If not, what will be required to do this? What parts are susceptible to fail at this rpm? Thanks in advance everyone
FR-S Mod target: 200 BHp / Tonne 4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff |
Drives: 2014 BRZ
Valve springs and retainers
Drives: 13 frs red
Valvetrain would shit the bed first imo. Did element ever release hp/tq numbers from their na project?
Site Moderator
Drives: ichi 86 Project
Like other have said, valves & retainer will go byebye, but also if you don't get proper bearings, your engine gonna be knocking really quick.
Last edited by ichitaka05; 07-20-2016 at 03:29 PM. Reason: Made a mistake wording it |
#5 | |
Drives: Raven Fr-S
How much can the stock valvetrain handle?
#6 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Why would you even want to rev past the stock redline, power just dies after that point |
Stock redline is 7400, so you're adding 1100rpm to get to 8500.
As was already asked, why do you want to rev that high? The stock cams (and probably intake manifold) just won't make any power up that high.
#8 | |
Site Moderator
#9 | |
Drives: '95 delSol, '13 EvoX, '14 Leaf
For high rpm, you typically upgrade the valve SPRING and retainer to fit the new spring. The valve itself it typically OK, but it never hurts to upgrade and freshen up the seats while you're in there. Understood. Makes sense. Got it. But in my ~17 years in the racing industry I've never heard or read anything about high rpm piston rings or their correlation to engine knock. Piston weights go down as desired rpm goes up, skirts shrink, maybe you only run 2 rings instead of 3, but as far as I know they all use the same rings, and the rings have 0 to do with knock... Can you reference or link anything I can learn from? |
#10 | |
Site Moderator
Hopefully that clears up some confusion |
#11 |
Drives: 2013 Ultramarine FR-S
FWIW Element is running to 9k with a large turbo, upgraded valvetrain (Springs/Retainers), Larger Exhaust valve, and internal oiling mods/Accusump system to keep the oil pressure good.
Lot's of info here: Element Tuning FA20 Major issues are going to be valvetrain, oil pressure, and the fact a stock engine probably isn't going make power that far out
#12 |
Drives: blue - Cosworth SC stage 3.0
agreed
to make power up at that point you'll need to re-tune the engine so a shorter inlet manifold and shorter exhaust primaries and cam timing adjusted to suit and then as others have said to make it mechanically live that those rpms will need a stronger valve spring at the very least and some re-working of the oil pump as the oil pressure is dropping off pretty quick by this point there's a reason why FI is so popular on this engine |
#13 | |
Drives: Raven Fr-S
Another reason for me wanting a slightly higher rev limit is to avoid shifting to 3rd in some of the faster autocross courses, and to avoid shifting to 5th at turn 16 and the start/finish straight at PittRace.
#14 |
Drives: 13 frs red
Change the cut out to 8600 and tie a mulch bag to the rear bumper.
| 2014 6MT FRS Monogram 8500 Miles Lease swap $297/month | momo3605 | Cars for Sale/Trade | 3 | 05-11-2015 03:35 PM |
| IN: 2013 Scion FRS Ultramarine (8500 miles) | Spirit7 | Cars for Sale/Trade | 21 | 03-04-2014 12:38 PM |
| Anything else needed? | Ymerej | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 02-03-2014 09:33 PM |
| Escort Passport 8500 x50 | Nassty | Miscellaneous | 1 | 11-13-2013 07:28 PM |
| FS (UT): Whiteout FRS, 8500 miles, Volk, Tein, Cusco | Tanuki | Cars for Sale/Trade | 15 | 07-28-2013 11:30 AM |
