Old 07-20-2016, 09:16 AM   #1
Kris86
Kris86's Avatar
Drives: RHD Gt86
Reimax Oil Pump Gear Kit
Has anyone done a review on these?
anyone got to see if they are they actually any stronger?
http://www.rhdjapan.com/reimax-oil-p...20-brz-86.html
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 07-20-2016, 09:35 AM   #2
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Element tested them on their racecar, no positive results to report.
As far as stronger is concerned... Nobody has ever broken the stock gear. It's not like the old RB and SR motors which used to shatter their sintered oil pumps.
Ours is such a sad sack of sh*t it won't make the pressure to shatter.
There's a possibility it may help people maintain oil pressure with extreme high rpm operation but that's unverified.
According to Element, It's supposedly slow to build pressure at low RPM, but math says it's a higher volume pump.
Tl : Dr no good information on it yet
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 07-20-2016, 09:41 AM   #3
Kris86
Kris86's Avatar
Drives: RHD Gt86
Tlr no good information on it yet
thanks for your info!
but spitfire just had his own explode on him on the track this week
Old 07-20-2016, 10:09 AM   #4
FRS Justin
Drives: 2013 Asphalt FRS
I treated my factory gears and that's it. You have the everything you need, balance that pig and put it together.......
Edit: Remember your not going to be spinning 8500 to 9000 rpm and your not shooting for 1000hp so you really have all the major components needed. You have to draw a line on what your goals are and what you need or building a motor will get 2x more expensive than it needs to be..... IMHO your rockers, oil pump will be more than enough to do what you want to do.. Just my 2 cents brother
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 07-20-2016, 10:11 AM   #5
Spartarus
...Just add nauseum
Spartarus's Avatar
Well son of a b*tch.
Something new happens every week.
-Spartarus
Old 07-20-2016, 10:16 AM   #6
makinen
makinen's Avatar
Drives: Toyota 86
At least this member has (maybe) good result.
http://www.ft86club.com/forums/showp...&postcount=191
makinen is offline   Reply With Quote
Old 07-20-2016, 10:22 AM   #7
FRS Justin
The only way I see these gears breaking is a piece of debris from the motor getting in the pump.... Or damaged gears from the start...
710whp
Old 07-20-2016, 10:46 AM   #8
Kris86
Kris86's Avatar
Drives: RHD Gt86
thanks a lot Justin. appreciate this
Old 07-20-2016, 11:54 AM   #9
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
no idea why mine shattered. brand new front cover/ oil pump. every part of the rotating assembly was balanced out, bearing clearance was perfect and held 90psi at 8500rpm. motec logs were perfectly clean until it let go. car made many pulls without issue. sometimes shit happens i guess lol. I have never seen another one fail. if i was rebuilding id more than likely just run another oem one and not worry about it happening again.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 07-20-2016, 12:35 PM   #10
FRS Justin
That's just crazy... I know you guys do awesome work so that just leaves fate...... How much power did you make, what weight of oil did you run? These are questions that might just help find the limit of the FA20.... PM me if you feel like comparing notes..
710whp
Old 07-20-2016, 01:14 PM   #11
spitfire481
Drives: 2JZ FRS
Never went more than 670whp at 28psi. Never turned it up after I put the id2000's in. Brad penn 10w40, same as my last motor. Clean log. No knock, no noises, no failed injectors or compensation taking place. I'd call it a random failure like you said earlier. Until someone else has one fall apart I wouldn't consider it an issue
MoTeC
Build Thread
@spitfire481
Old 07-21-2016, 06:34 AM   #12
Calum
That Guy
Drives: 2013 asphalt FRS MT
Oh, that's so sad. How do you live with such low power... /s
Old 07-21-2016, 11:04 AM   #13
spitfire481
Drives: 2JZ FRS
after a day it doesn't feel that fast anymore, ask @FRS Justin how that goes lol
MoTeC
Build Thread
@spitfire481
Old 07-21-2016, 11:37 AM   #14
FRS Justin
Oh it's no big deal, all 86s are slow so I'm told.... lol
710whp
Gear indicator (G-on) shows 2 when in 3rd gear c8Face BRZ First-Gen (2012+) — General Topics 31 07-07-2017 07:23 PM
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 06:28 PM
Auto gear slippage on 2nd n 3rd gear shantha Scion FR-S / Toyota 86 GT86 General Forum 2 11-19-2015 07:26 PM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
