Old 07-20-2016, 09:56 AM   #1
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
Compact spare in the rear
The FRS manual says that the compact spare should be only used in the front. If you have a flat in the rear, you should put the donut in the front, and the normal front wheel in the rear.
Why is that? Clearances in the rear? LSD gets confused? Nannies get confused?
Do you guys observe this? Has anyone had problems due to putting the donut in the rear?
Also, has anyone tried to have insurance-covered roadside assistance replace a rear flat properly, i.e., demand that that they do the swap, meaning twice as much work? Did they do it?
mdm is offline   Reply With Quote
The Following User Says Thank You to mdm For This Useful Post:
kthxbai (07-22-2016)
Old 07-20-2016, 10:07 AM   #2
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Good way to say goodbye to your diff....
Cockatoo is offline   Reply With Quote
The Following 4 Users Say Thank You to Cockatoo For This Useful Post:
funwheeldrive (07-20-2016), jawn (07-22-2016), kch (07-21-2016), mdm (07-20-2016)
Old 07-20-2016, 10:19 AM   #3
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
At least they give you a spare - so many sports and performance cars do not these days.
Sport-Tech is offline   Reply With Quote
Old 07-20-2016, 10:45 AM   #4
Rear wheel drive combined with two different tire sizes is a recipe for bad news. Ultimately, 99% of people will probably never realize they should do this, but the manual covers Toyota for liability when you go sliding off the road sideways.
mdm (07-20-2016)
Old 07-20-2016, 10:47 AM   #5
mdm
not a twin owner
mdm's Avatar
OK, but why exactly? From the point of view of the diff, driving on the donut is like driving in a gentle turn all the time. Surely there would be some strain, but how is it worse from driving fast and hard on a winding race track?
Old 07-20-2016, 11:28 AM   #6
Cockatoo
TALLY FT86
Cockatoo's Avatar
If you are driving with any kind if speed with massively different diameter tires on the rear, it is way more stress than "driving in a gentle turn". The diff is working hard to spin those wheels at the same rate, and a lot of heat builds up.
The Following User Says Thank You to Cockatoo For This Useful Post:
mdm (07-20-2016)
Old 07-20-2016, 11:56 AM   #7
mdm
not a twin owner
mdm's Avatar
If you are driving with any kind if speed with massively different diameter tires.
By my calculation, the [nominal] difference in diameter between the T135/80D16 spare and the 215/45R17 regular tire is 0.5%.
That's equivalent to the difference caused by a 300-m radius turn. Is that massive?
Or is the actual difference in diameter larger than the nominal difference, e.g. becuase the spare and the regular tire compress very differently?
Old 07-20-2016, 11:58 AM   #8
FX86
remove spare tire because weight reduction
The Following 2 Users Say Thank You to FX86 For This Useful Post:
Romanov (07-20-2016), Swagopopotamus (07-20-2016)
Old 07-20-2016, 01:32 PM   #9
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
If I'm not mistaken,you aren't supposed to put a donut on the driving axle. So if you have a flat on a FWD you should always have the donut on the rear,even if you have a flat in the front.
I'm pretty sure most AWD cars spares are the same size as the OEM size wheel,and of course,Jeeps,SUVs,and the like have full sized spares.
Th3rdSun is offline   Reply With Quote
The Following User Says Thank You to Th3rdSun For This Useful Post:
TheVoiceOfReason (07-20-2016)
Old 07-20-2016, 01:39 PM   #10
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
It's because of the diff. Certain LSD can be damaged by 2 tires of dissimilar diameter being mounted on the drive axle. This is why it's important to rotate tires on schedule and never install 2 different brands of tires or 2 tires with very different wear on the drive axle.
That said, the manual is being anal about it. You aren't supposed to go more than 50 miles or 50 mph on the donut anyway and you won't blow out the diff.
Don't be a lazy ass. Just put the donut on the front. If you are a lazy ass and call aaa to come change your tire 1) shame on you 2) if you insist that the aaa man install the donut on the front you had BETTER give him a good tip ya ****.
-your friendly AAA man who's sick of changing tires for snotty lazy asses
Old 07-20-2016, 02:23 PM   #11
mdm
not a twin owner
mdm's Avatar
I have never seen an FWD manual saying so.
Old 07-20-2016, 02:24 PM   #12
mdm
not a twin owner
mdm's Avatar
I am not saying I wouldn't do so. I am just curious why is this exactly recommended, especially that by my calculations (which might be wrong) driving with a donut is equivalent to a relatively mild turn.
Old 07-20-2016, 02:35 PM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Basically it's putting excessive strain and heat on the diff, about the same as if you were to drift on the stock Torsen.
Assuming the average driver and lack of mechanical knowledge, you'd have a premature warranty case that may get denied by corporate due to "abuse"
-alex
Old 07-20-2016, 02:41 PM   #14
extrashaky
Drives: 2014 BRZ Limited
I suspect if you put the donut on the rear, the wheel speed sensors are going to throw a code, freak out completely thinking you're skidding around in a circle and send the traction control into a panic. Even if it doesn't damage the diff, I suspect it would make for an unusual driving experience.
Anybody have a source for Australian parts? The Aussies have an option for a full sized spare that has a different trunk floor and tray. I would love to be able to order those parts at a reasonable cost.
Mishimoto Compact Baffled Oil Catch Can Build Thread! Mishimoto Engine, Exhaust, Transmission 81 08-21-2019 09:05 PM
Anyone Have Spare Stock Taillights/Rear Fog I Can Borrow? AdamBomb518 Mid-Atlantic 5 02-25-2014 05:07 PM
Buschur Sport Compact Shootout (May 26th) CaptainSlow Great Lakes 0 05-21-2013 02:24 PM
My FR-S is so compact.... FRiSson Scion FR-S / Toyota 86 GT86 General Forum 41 12-03-2012 04:54 PM
Found a recent 3 door RWD compact... Allch Chcar Other Vehicles & General Automotive Discussions 50 05-30-2012 04:22 PM
