Drives: Scion FRS 10 Series
CEL
Ok guys. So, I have a small issue. My CEL came on one day and I started to lose power at certain rpms. I went to Toyota and had them diagnose the problem. They came with 2 codes. P219a, and P119f. Since I was running ethanol they told me to just run 93 for a while and clean out the system with some injector cleaner. It has been more then a week now and even though I dont lose power anymore. The CEL keeps coming back with the same codes.
Any ideas on what i can do to stop the ECU from reading the same codes?
10 Series Owner. Love it.
#2 | |
Drives: 2014 BRZ Limited 6MT
have you checked under the hood to make sure the engine is still there?
Señor Member
Dumb question but i have to ask..... You are running a tune for e85 right?
Yes, I am tuned. However, at this point in time im running my stock tune.
#9 | |
what tune are you using for e85 straight e85 tune or full flex kit or map switch ? e85 will clean out the system bettercthan 93 your getting those codes as you have either a hardware problem like exhaust intake leak or bad sensor o2 maf or dirty maf from oiled filter. low fuel pressure, leaking injector or your running incorrect tune for e85 |
