Old 07-19-2016, 01:11 PM   #1
Cojonudo
I'm New
Cojonudo's Avatar
Drives: 2016 Limited Subaru BRZ White Pearl
Question Eibach Pro Kit or Sportline for 2016 BRZ
Hello, I've been looking around the forum and trying to research the difference between the Eibach Pro Kit and the Sportline Kit for a 2016 BRZ but only seem to find older models. I think there is no difference between the suspension of previous BRZ models but I could be wrong. I just wanted to ask some questions and hopefully some of you guys could lead me in the right direction. I'm looking for a drop that won't be too low and I won't scrape which I think both springs are fine for that.
My main concern is if I will need to upgrade my shocks and struts if I get the Sportline? I'm currently running stock 17 inch wheels on my BRZ but in the future I plan on getting 18s will the Sportlines be too low for 18s? I don't want my tire rubbing. Right now I'm leaning more towards the Pro Kit but I also like how aggressive the BRZ looks with the Sportlines it just all depends if I will need to get new shocks and struts for the Sportlines, if I do I would just get the Pro Kit or just buy coilovers. Thanks! Any help and insight would be appreciated.
"You do you"
Cojonudo is offline   Reply With Quote
Old 07-19-2016, 01:15 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
I have sportline on a 2014 BRZ with standard shocks and OEM wheels with spacers. The ride is firmer and ride height is very notable.
Old 07-19-2016, 05:15 PM   #3
Jackiepoo
Jackiepoo's Avatar
Drives: 2015 Raven 6mt
I have sportlines on stock shocks with 18x8 wheels. The ride is definitely a lot firmer and the drop is significant enough to cause slight negative camber in the rear. Nothing too extreme but it is present.
Jackiepoo is offline   Reply With Quote
Old 07-20-2016, 09:35 AM   #4
SubaruLifer
Drives: 2015 ISM BRZ Premium
You're not going to suddenly start rubbing just by moving to 18" wheels. Generally you'd go with a tire that has a shorter sidewall than stock to get a similar overall diameter.
SubaruLifer is offline   Reply With Quote
Old 07-20-2016, 10:25 AM   #5
TatharPallan
Drives: 2015 Subaru Blue Series - Pearl
Both are intended to be used with OEM shocks.
Sport-lines provide about a 1.5 inch drop. Intended for looks
Pro-kit provide about an inch drop. Intended to improve handling.
I've actually just installed the Pro-kit about a week ago. Feels slightly firmer than Stock on straight bumpy roads. The biggest difference is less body roll in the corners.
2015 BRZ Series.Blue CWP (K1X) - JDL UEL Header, 3" JDL Res FP, 3" JDL OP, 3" Perrin Res Cat back, 3" Perrin BigMAF Intake/Inlet tube, Perrin Light Weight Pulleys (AC, Water Pump, Crank) - Moto-East FFK - E85 Tuned by HRI - ECUTEK - Eibach Pro-Kit Lowering Springs
TatharPallan is offline   Reply With Quote
Old 07-21-2016, 11:42 PM   #6
perryair
junior mafia
Drives: ‘20 sti limited
id probably not do sportlines unless you are also going to do rear lca's. i have the pro-kit and the rear camber is fairly noticeable, also that almost an inch drop means that even if there is a dip divot in the road surface or you encounter a little offroad segment of a road, you're prone to scraping, which i've done about 2-3 times so far. its a decent drop, way more than enough unless you like it really dropped.
for the inch and a half look, you're likely better off getting a set of more price efficient coilovers and going that route.. but thats just my opinion..
20 sti limited | 17 bmw m240i | 16 scion im |15 brz limited {prokit, 17x8 +35 rpf1, bfg comp 2 a/s, stg 2, jdl uel, voodoo knob} | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
perryair is offline   Reply With Quote
Old 07-22-2016, 05:18 PM   #7
Filipino Royale
Got Rice?
Filipino Royale's Avatar
Drives: 37J BRZ-L
i have the prokit and i loved it i have 1 season of TimeTrial here in Northeast, less body roll and pretty aggressive on the corners. good learning springs if your autocrossing or tracking the car. picture on my signature is still on the prokit springs. if u decided to get a prokit mines for sale, just let me know.
Be a Leader, Be a Friend, Be at Service. -AɸΩ
Filipino Royale is offline   Reply With Quote
Old 07-26-2016, 04:07 PM   #8
Romanov
Just another BRZ owner
Romanov's Avatar
Drives: 2014 Subaru BRZ Limited MT
I feel like i roll more with my pro kit. But when i did the install i went directly to 18x8 wheels with Pilot super sports. Sticky tires cause me to roll a little more.
Going to Coils to go lower.
I wouldn't do sportlines, my friend had it on his car for a while but got annoyed at the noticeable change ride quality without getting the coilover-like performance he wanted.
2014 Dark Grey Metalic Subaru brz limited 6 MT
Follow my Instagram @sal_brz
Romanov is offline   Reply With Quote
Old 07-26-2016, 04:13 PM   #9
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Im on RSR Superdowns which are similar to the sportlines except the drop is staggered.
1.2" Front
1.4" Rear
Aesthetically I think its the perfect drop, I do not desire go any lower. The extra rear camber didn't really cause much more tire wear (stock LCAs). The ride is MUCH firmer, but I don't really mind eventually I'll pair the springs with some Koni Yellows it'll be a good combo.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
FS: Eibach Sportline Springs Ymerej NY / NJ / CT / PA 1 02-02-2014 05:50 PM
WTB: Eibach Sportline Springs djtre Want-To-Buy Requests 4 07-16-2013 07:25 PM
Eibach sportline ThatManAnt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-01-2013 01:20 PM
Eibach Pro-Kit vs Sportline itisthumper Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 01-03-2013 02:27 PM
