Drives: 2015 FRS
Help finding thread?
Can anyone direct me to threads where I can find info on stance (wheel fitment, coilovers, brake clearance, offset, camber..)..?
Not looking to slam but I do want to lower to improve overall cosmetics but not CRAZY low or a ton of camber you know? Just a clean look. No idea where to start or what wheel/tire brands to look at or what will even fit/ look nice and flush with fenders and such.. Also not sure if I need fender rolling or not.. BASICALLY I know nothing as to what to search for. All I know is what I think looks nice ¯\_(ツ)_/¯ Pictures of your setups will also be a plus! Thanks, Forum noob |
Drives: 15 BRZ LTD, 05 FXT
I suggest looking in this subforum. There are TONS of people posting their fitments with different wheels and what suspension they are on.
It's common to do a 1" drop with 20mm spacers on the stock wheels as it kills the wheel gap, and handles well without costing much or ruining geometry, though it's best to add LCA's with a toe arm solution, (like the SPC), and camber bolts.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
| The Following User Says Thank You to JazzleSAURUS For This Useful Post: | mattaubel (07-18-2016) |
Drives: FRS
i would begin with looking through the different suspension setup threads. most people in those threads will have aftermarket wheels. then after, i would look through the wheel directory thread to see the different sizes/styles with tires and see how they fit. at the end, itll basically be a combination of both wheel/tires and suspension as this is the only way to figure out "wheel fitment". cant have one without the other
| The Following User Says Thank You to 8R6 For This Useful Post: | mattaubel (07-18-2016) |
| BRZ NAV not finding satellites | DSPographer | Electronics | Audio | NAV | Infotainment | 116 | 01-05-2020 08:42 PM |
| FINDING SBD TURBO KIT THREAD | myioz86 | Forced Induction | 2 | 01-20-2015 11:00 PM |
| Need help finding Part # | 914_WHITE_FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-17-2014 07:41 PM |
| need help finding this | Shipwreck | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 05-24-2013 12:06 AM |
| Help finding thread about startup rpm needle | Prava | Electronics | Audio | NAV | Infotainment | 2 | 07-01-2012 01:29 PM |
