Old 07-07-2016, 09:01 PM   #1
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Transmission knock
After doing the dss aluminum driveshaft and changing over to the motul 300 75w-90 sometimes I notice a knock coming from the transmission. It only happens on start up after it's been sitting. Once it warms up after a minute drive it is gone and when I put the car away it isn't there. Is it just the motul being cold and needing to warm up or some other weird noise this car makes? Shift perfect no grinds or anything unusual .
tofurun is offline   Reply With Quote
Old 07-08-2016, 01:15 AM   #2
humfrz
Well, now @tofurun ........ you REALLY messed up this time .........
First off, you replaced a TWO piece driveshaft with a ONE piece driveshaft. So, when it cools and contracts, it PULLS on the gears of the transmission apart, thus when they are started up they SLAM together, causing that KNOCK.
Of course this sends a SHOCK through the drivetrain, which is transferred to the differential and will eventually knock a tooth off of the ring gear.
In addition, the SHOCK wave will be transmitted through the shafts in the transmission into the clutch assembly and will, in time, put the pressure plate out of balance and not only scar the flywheel, but will BLOW up the clutch disk and FREEZE the throw out bearing.
Next, you will hear the dreaded "neutral rollover" ask @Ultramaroon for details, which is nothing more than the inability of motul gear oil to deal with the shock waves ....... leaving the gears and bearings to grind themselves to oblivion.
I'm sorry for your impending disaster .......
humfrz
The Following 5 Users Say Thank You to humfrz For This Useful Post:
chaoskaze (07-08-2016), Drakiv (07-08-2016), go_a_way1 (07-08-2016), gramicci101 (07-08-2016), Tcoat (07-08-2016)
Old 07-08-2016, 01:23 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
well, that was painful.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
chaoskaze (07-08-2016), gramicci101 (07-08-2016), humfrz (07-08-2016), Tcoat (07-08-2016)
Old 07-08-2016, 02:46 AM   #4
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Old 07-08-2016, 06:27 AM   #5
tofurun
tofurun's Avatar
humfrz
Why you gotta make my life so difficult....
The Following User Says Thank You to tofurun For This Useful Post:
humfrz (07-08-2016)
Old 07-08-2016, 04:28 PM   #6
humfrz
Sorry .....
How about this:
In the driveline, between the back of the crankshaft and the wheels are many moving parts (like for example, the clutch, TOB, pressure plate, transmission gears and bearings, universal joints, ring & pinion gears and real axle universal joints).
So, for the car to move, they must all "tighten up" ...... thus the "knock" sound. Quite normal.
Now, you fell better ??......
humfrz
Apoc (07-08-2016), tofurun (07-08-2016)
Old 07-08-2016, 05:32 PM   #7
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I liked the first answer
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 07-08-2016, 05:45 PM   #8
tofurun
tofurun's Avatar
Sorry .....
How about this:
humfrz
TY lol
Yea i knew it was coming. I read a few posts before posting and it sounded like the same issue I was having. I just didnt notice it until after the Fluid and DSS change, wasnt sure if it may be something different. Been discussed 100 times
humfrz (07-08-2016)
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
FR-S Rod knock pozer Issues | Warranty | Recalls / TSB 95 11-03-2015 09:39 AM
Oft knock brady86 Software Tuning 26 07-15-2015 10:14 PM
Tip in knock? bmsi30 Issues | Warranty | Recalls / TSB 17 08-25-2014 04:12 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
