Old 07-06-2016, 09:48 PM   #1
HuntingtonFRS
Drives: 2013 Scion FR-S in White
Too much air going out?
I have the Tomei UEL, Invidia Q300 2.5" exhaust, and just added JDL over pipe/front pipe but it's 3".
I'm running the HKS supercharger. My question, is this too much air going out now? Not enough back pressure? Is that really possible being boosted?
HuntingtonFRS is offline   Reply With Quote
Old 07-06-2016, 10:37 PM   #2
D_Thissen
D_Thissen's Avatar
It's fine, don't worry.
Edit: In regards to back pressure. Here's a comparison between a 2.5" and 3" exhaust.
[ame="https://www.youtube.com/watch?v=_PVXvHkr-Vs"]The Power of 2.5- vs. 3-Inch Exhaust - Engine Masters Ep. 9 - YouTube[/ame]
Old 07-06-2016, 11:08 PM   #3
HuntingtonFRS
That's really interesting. Does it make the same difference on lower horse power vehicles though? I feel like there are more factors than just what they tested when comparing vehicles.
Old 07-06-2016, 11:14 PM   #4
FRS Justin
Drives: 2013 Asphalt FRS
Forced induction takes the worry away from back pressure loss..
Running forced induction forces the air into the cylinder and that offsets the need for exhaust scavenging..
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 07-06-2016, 11:52 PM   #5
KoolBRZ
KoolBRZ's Avatar
No such thing as too much air
Too much air no, too much velocity, maybe. Valve timing controls the flow of air and fuel through the cylinder. Air Intake and exhaust restrictions affect the velocity of that flow. Remove some of the exhaust restriction and you change the velocity of flow through the cylinder. Before I complicate things with AVCS valve timing, Injector angles and other complicated stuff, answer me this, how does your car sound now? Is it more brassy sounding, like a trumpet? Or is it more brrrrrraaaaappppppp'y? There is a happy medium between the two which makes the most power. The only way to make sure, is to use tunes ranging from too little AVCS advance to too much advance. The tune between brassy and brrrrrraaaaappppppp'y is the one making the most power. Then the challenge is making the same sound throughout all loads and rpms.
Chances are if your exhaust has changed your restriction too much, your car will sound more brassy, and have less low end torque under medium to heavy loads. If this is happening, contact whoever made your tune and see if they will adjust it for you.
If I say yes, will that make you think I understand?
Old 07-07-2016, 03:30 AM   #6
Poodles
Drives: 2015 Series.Blue
There. Is. No. Such. Thing. As. Backpressure.
Old 07-07-2016, 03:45 AM   #7
swarb
You is wrong
Old 07-07-2016, 10:29 AM   #8
HuntingtonFRS
My car has constipation? Lol
Old 07-07-2016, 01:34 PM   #9
wparsons
wparsons's Avatar
Removing restrictions too far (most common from too large of a diameter exhaust) will typically give lower exhaust velocity, not higher. There's a sweet spot for velocity for good scavenging (and maximum power).
On a turbo car, the turbo itself is much more of a restriction than anything after it, so the best exhaust is typically the one that has the least restriction possible.
On a supercharged car you can still have benefits from scavenging, but it's not as important.
As for the original question, going to a 3" front pipe isn't going to change overall flow/velocity much since it still has to go through the 2.5" Q300 to get out. That said, testing shows that a good 3" exhaust will make more power than a good 2.5" exhaust, even N/A, on these cars.
flickr
Old 07-07-2016, 02:14 PM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
wparsons: testing, 3" win, .. you mean perrin one? But IIRC it was with stock header, no? Don't know if it would be same way with 3" exhaust AND catless aftermarket headers .. rather i'd bet on bolt-on mods cumulative gains hitting diminishing returns and there to be of little difference between 2.5" vs 3" NA.
Old 07-07-2016, 05:10 PM   #11
wparsons
wparsons's Avatar
Look at the dyno thread(s) from the nameless header, definitely more important with an aftermarket header than the stock one.
There is a point of diminishing returns, but the point was that going to a 3" exhaust isn't going to make you lose power over a 2.5", there's still plenty of exhaust velocity.
flickr
Old 07-08-2016, 01:10 AM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
wparsons: thanks for info.
I won't go 3" it route anyway though, as it usually is reported as being louder, hence bad companion to exhaust that will be already louder due catless aftermarket header, hence combo might get above reasonable noise level, from what i see seeing several posts of users switching back to stock or Q300 when they installed header after catback.
Old 07-08-2016, 01:45 PM   #13
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
Backpressure is a myth created by hotrodders.
Scavenge effect is real.
COO86L is offline   Reply With Quote
