Old 07-06-2016, 02:36 PM   #1
KieranH
Drives: Subaru BRZ
Camber
Hello,
I've looked around for camber kits and usually come across rear lower control arms, I believe this is all you need to camber the rear wheels. I've been recommended to get rear toe control arms aswell. Now do I also need rear upper control arms?
Someone mentioned to me to get ones that are adjustable by arm and not bolt. If anyone is willing to help me and recommend me parts/manufacturer to point me in the right direction that would be much appreciated.
Thanks in advance.
KieranH is offline   Reply With Quote
Old 07-06-2016, 03:00 PM   #2
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
What are your goals?
Are you correcting or creating camber? and how much?
VIP BRZ is offline   Reply With Quote
Old 07-06-2016, 03:01 PM   #3
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
How far do you want to go?
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 07-06-2016, 03:42 PM   #4
strat61caster
strat61caster's Avatar
If you're trying to keep the car setup for street or track/auotcross with the rear camber between 0 and -3 degrees the stock toe arms are fine.
imo the bolt adjustment is easy on the OE rear toe arms.
ineedyourdiddly
Cole (07-06-2016)
Old 07-06-2016, 06:17 PM   #5
swarb
Can slip
Can't slip
Toe arms aren't needed unless you go super low or want lots of camber.
Upper control arms aren't needed.
Old 07-06-2016, 07:28 PM   #6
KieranH
Drives: Subaru BRZ
I'm looking to create camber. So preferably as much as I can to make the wheels fit.
As much that is necessary to make wheels fit in the arches when aired out.
Originally Posted by swarb View Post
Can slip
Can't slip
Sounds like I'll need toe arms aswell. What do you mean by can/can't slip?
Old 07-06-2016, 09:47 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
can slip = may not hold adjustment
Old 07-06-2016, 10:58 PM   #8
jbailey8748
The whiteline/spc lca adjustments wile the look like they could slip it is highly umlikley
Old 07-06-2016, 10:58 PM   #9
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Thats got me a bit worried, i was planning to go with SPC LCAs because I heard good things about them, including from the shop I use (AZP)
PandaSPUR is offline   Reply With Quote
Old 07-06-2016, 11:03 PM   #10
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I have the newer Whiteline LCA's and they've never slipped from street driving or Autocross. These are basically the same as the SPC's.
smg1138 is offline   Reply With Quote
The Following User Says Thank You to smg1138 For This Useful Post:
jbailey8748 (07-06-2016)
Old 07-06-2016, 11:09 PM   #11
Ultramaroon
not playing cards
I just clarified because swarb went offline. As long as I butted into the conversation here's my take. In the event of a mishap the stock LCAs are designed to deform before passing the energy to more expensive parts. I'm not a fan of the super stiff aftermarket LCAs for that reason. If I had to choose, I would go with the SPC units.
PandaSPUR (07-06-2016), Toyarzee (07-06-2016)
Old 07-06-2016, 11:11 PM   #12
jbailey8748
Don't be worried. These would be what the factory did if the decided to put adjustment in the rear lca
The Following User Says Thank You to jbailey8748 For This Useful Post:
Old 07-06-2016, 11:22 PM   #13
PandaSPUR
PandaSPUR's Avatar
Ah ok, that makes me feel much better. In that case, I too would prefer the SPC units.
I only need LCAs to address any potential stock camber differences between left and right, and to fit some meaty tires anyway. Dont care for the fancier looking units.
Old 07-07-2016, 01:48 AM   #14
Filipino Royale
Got Rice?
Filipino Royale's Avatar
Drives: 37J BRZ-L
Im selling my spc LCA, im in NY too. And can point u to right direction to have it aligned too.
Be a Leader, Be a Friend, Be at Service. -AɸΩ
Filipino Royale is offline   Reply With Quote
This is how camber affects toe in front. Also RCE camber plate info. Pat Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 05-04-2016 10:08 PM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
