Old 07-04-2016, 09:58 AM   #1
killercl0wnfish
Drives: fr-s
searching for a hour no luck will these fit
19x10+26 mid disk 4" lip
5x100 original
killercl0wnfish is offline   Reply With Quote
Old 07-04-2016, 10:24 AM   #2
gramicci101
Off Topic
Here's an 18x10 +25, so it's 1mm different in offset. Look at the camber he's having to run to get the top of the wheel back into the fender. If that's the look you're going for, then great. There's a lot of parts and work involved to get them to fit though.
http://www.ft86club.com/forums/showthread.php?t=22655
Old 07-04-2016, 11:45 AM   #3
killercl0wnfish
Drives: fr-s
I found a set that are 18x9.5 +20 looks like they will be a better fit I can't run to much camber due to being 2j swaped I want the as much tire as possible on the ground
Old 07-04-2016, 11:48 AM   #4
killercl0wnfish
Drives: fr-s
I like the battle stance look. I can't be go low due to 3.5 inch exhaust might switch exhaust with oval pipe to help get more room
Old 07-05-2016, 12:36 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
+20 fits with poke. If that is your thing.
Old 07-05-2016, 02:30 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
As much tires as possible (in the rear)?
9.5" and a +35 or +40 offset. Or 10" around the same.
We had 275 Hoosiers on 18x10" wheels in the rear with minimal fender roll. You'll just have to stagger your setup since the engine will give a lot of power oversteer anyhow.
-alex
Searching for fog light bezel idover Cosmetic Modification (Interior/Exterior/Lighting) 1 03-11-2022 09:39 AM
Searching for correct fitment Lischynski Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 05-17-2014 07:35 PM
Still searching for an FR-S? 2 available in Little Rock Moshpit37 Southwest 9 01-02-2013 10:32 AM
Searching Inventory in the SE Erroneous Southeast 40 07-23-2012 04:40 PM
