Old 06-26-2016, 06:11 AM   #1
tracerit
Drives: '13 SSM BRZ Limited 6MT
Is the butterfly valve in the throttle body supposed to be closed shut?
I had high negative LTFT (-10 to -15%) on idle and off throttle for a while when I had my Perrin CAI installed. Also had rpm dips when I came up to a stop that would blink off my DRL LEDs. But now it's back to normal (positive 2-5%) with my stock airbox installed.
During the swap, I noticed the butterfly valve in the throttle body was slightly open. Picture is attached. Is this normal?
http://imgur.com/cFZvyWk
tracerit is offline   Reply With Quote
Old 06-26-2016, 10:09 AM   #2
D_Thissen
D_Thissen's Avatar
You need to scale the MAF when running an aftermarket intake such as the one from Perrin.
http://www.ft86club.com/forums/showt...01#post1842501
http://www.ft86club.com/forums/showthread.php?t=83945
IIRC it is normal for the throttle to be open a little bit.
The Following User Says Thank You to D_Thissen For This Useful Post:
tracerit (06-26-2016)
Old 06-26-2016, 02:34 PM   #3
humfrz
Well, I know nothing about throttle bodies on these cars ........ but, I would speculate that it would be normal to be partially open sometimes ...... if it were completely closed ...... how would the engine get any air ......
humfrz
The Following 4 Users Say Thank You to humfrz For This Useful Post:
akyp (06-27-2016), brianhj (06-28-2016), COO86L (06-27-2016), tracerit (06-26-2016)
Old 06-27-2016, 03:05 AM   #4
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
Took the words right out of my fingers @humfrz
COO86L is offline   Reply With Quote
The Following User Says Thank You to COO86L For This Useful Post:
humfrz (06-27-2016)
Old 06-27-2016, 11:33 AM   #5
jwvand02
Drives: 2013 SWP BRZ Limited
yes, the throttle body stays slightly open. I had the same concern the first time I took mine off
jwvand02 is offline   Reply With Quote
Old 06-27-2016, 06:12 PM   #6
86drift
86drift's Avatar
Drives: Toyota 86 GT
The neutral position for the throttle body is slightly open. This position is close to where it sits at idle.
The ECU can fully close it. Also, it can go past fully open...
86drift is offline   Reply With Quote
SSP AT Valve Body Upgrade nlowell Engine, Exhaust, Transmission 39 05-30-2017 04:32 PM
Variable Valve "Butterfly" Exhaust dlux Southern California 19 02-22-2016 06:21 PM
Manual/Automatic Valve Body Nevermore Other Vehicles & General Automotive Discussions 4 09-08-2015 12:15 AM
