Old 06-22-2016, 05:04 PM   #1
Hot Wheels
Drives: 2014 WRB BRZ Limited
DRL and fogs wiring help please.
The previous owner had under glow installed on the car, but removed it before I purchased. One of my fog lights went out today and I dug in to see the damage myself. It looks like an LED bulb, but the housing has all of this hard white clay/paste on it, and the plug does not look OEM. the wire bundle that gives power to the DRL and fogs was split and another plug (under glow i presume) was attached. As of now, the DRL only light with the high beams on. Any suggestions on how to return the DRL to stock operation? Pics of fog light housing and wiring attached.
Hot Wheels is offline   Reply With Quote
Old 07-11-2016, 04:38 AM   #2
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
That's not oem fog, the clay you mention is to seal or hold the bulb in place. You could remove it just cut it off and replace with an e bay fog light kit, or do what he did and reseal after replacing bulb 😅. I got my fog kit from diode dynamic which use connector to tap into low beam, so when low beam is on fog light auto on too.
For experience you could test by splicing into the oem harness one by one (I think only a few wire) to test which is for drl (drop handbrake while testing) won't hurt just wrap exposed wire with electrical tape when done. Black to black/ground than there's one more or power source which will be the one you'll be testing
or
Google which pin on oem harness plug is drl than splice there to be sure and save the trouble.
Sent from my SM-P600 using Tapatalk
turtlefeeder is offline   Reply With Quote
Old 07-11-2016, 10:53 AM   #3
Chimera
Drives: FRS
go ole JB weld, fixed the entire front end of a wrecked Lincoln Towncar with that stuff.
Its most def custom wiring.
Old 07-11-2016, 04:46 PM   #4
turtlefeeder
Drives: UltraMFrS
oh check this out someone's selling their diode dynamic fog kit for 80 bucks, I bought from diode dynamic originally for like 120 I think. here's a good oportunity to replace your fogs?
http://www.ft86club.com/forums/showthread.php?t=108220
Wiring BRZ rear fog light to only come on with front fogs Scenic Driver DIY (Do-It-Yourself) Guides 4 09-12-2015 09:36 AM
Amber fogs on brz? eSOLOR Cosmetic Modification (Interior/Exterior/Lighting) 12 07-18-2014 09:06 AM
HELP!!! Fog lights....LED DRL Fogs vs. Projector Fogs w/ Halo tiz22 Cosmetic Modification (Interior/Exterior/Lighting) 4 11-02-2013 01:57 PM
FRS fogs using BRZ stalk Sco2355 Cosmetic Modification (Interior/Exterior/Lighting) 0 02-18-2013 01:51 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 12:44 PM
