Old 06-21-2016, 04:45 PM   #1
D K
Stig's dark passenger
Combating blow by solution
Hello
Is there a well known, documented solution to deal with blow by in a boosted car?
Draining 4-6 fl oz after every session isnt working for me anymore...
D K is offline   Reply With Quote
Old 06-21-2016, 05:01 PM   #2
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Originally Posted by D K View Post
Hello
Vented catch cans
The Racers Line is offline   Reply With Quote
Old 06-21-2016, 05:03 PM   #3
D K
Originally Posted by The Racers Line View Post
Vented catch cans
Have that now....
Blows by through the filter
The Following User Says Thank You to D K For This Useful Post:
CounterSpace Garage (06-21-2016)
Old 06-22-2016, 10:09 AM   #4
mrk1
Drives: Sterling BRZ Ltd
Can you post more details on your setup, that seems like a lot of fluid
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 06-22-2016, 07:28 PM   #5
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
What size hoses are you using? 1/2 or 3/8? If I recall the smaller the lines the more oil will make it up to the can.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 06-24-2016, 08:31 AM   #6
AJPG
Drives: 22RE, FA20, 4G63
Hello
Soooo, it was working and out of the blue it start with the blow by oil, or it start that way from day one?
AJPG is offline   Reply With Quote
Old 06-24-2016, 10:39 AM   #7
toast
Drives: 14 BSP Edelbrock BRZ
Will the Crawford AOS work on your FI setup? I had one on my 08 STI and it worked so well I never had any oil loss between changes, eventually I stopped even checking. One winter I decided to take it off because of the gunk buildup I would have to clean out during freezing weather - apparently I had a decent amount of blowby oil loss that it was saving because oil ran low and I spun a bearing.
toast is offline   Reply With Quote
Old 06-24-2016, 12:15 PM   #8
DAEMANO
Time Traveller
Hello
4-6 ozs suggests that you have a problem. The amount of blowby youre getting should be a trickle not a pour.
Old 06-25-2016, 07:09 AM   #9
AJPG
Hello
Cr test?
Old 06-25-2016, 05:21 PM   #10
D K
Im considering that option.
Doing some research...
Old 06-25-2016, 05:55 PM   #11
Irace86
Drives: BRZ + Ducati M796
Should it matter how much boost or how much lateral g's someone is consistently putting the engine through?
Irace86 is offline   Reply With Quote
Old 06-27-2016, 12:47 PM   #12
AJPG
Hello
Do you use an oilcooler prior to or concurrently with the FI?
Old 06-27-2016, 01:02 PM   #13
AJPG
Hello
http://www.certechgels.com/
Old 06-27-2016, 08:10 PM   #14
GsxrMe
GsxrMe's Avatar
I think the blow by were talking about is gas making it passed the piston and blowing out the pcv or crank case. Not oil making it passed the piston into the combustion chamber.
2014 Subaru BRZ
Combating the heat toekneehair Forced Induction 823 12-23-2021 08:06 PM
Does you A/C blow cold? boredom.is.me Issues | Warranty | Recalls / TSB 45 07-29-2017 03:04 PM
catch can for blow-through maf jamesm Forced Induction 13 05-25-2017 10:54 AM
Huge blow-out bestwheelbase Announcements, Contests, Giveaways 3 12-16-2013 06:08 PM
Blow through vs draw through MAF mrk1 Forced Induction 9 07-24-2013 07:21 AM
