Old 06-13-2016, 05:00 PM   #1
daironchef
Drives:
OEM vs aftermarket oil pan
Just wondering if anyone upgrade to a aftermarket cast aluminum oil pan? If yes, did you have to get new fittings, my fittings are ss, and I assume it doesn't weld on aluminum. And are the OEM ones steeles?
Sent from my Nexus 6P using Tapatalk
daironchef is offline   Reply With Quote
Old 06-14-2016, 03:51 AM   #2
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Factory pan is steel. Are you referring to turbo oil return line? You can get aftermarket alum fittings to weld onto an alum pan, but I'm pretty sure the FBM cast pans already have an extra hole which you can thread NPT fittings into for the oil return.
Fizz is offline   Reply With Quote
Old 06-14-2016, 04:47 AM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
What type of oil return do you want to run, and where?
Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic ecko04 Electronics | Audio | NAV | Infotainment 10 05-05-2018 03:47 PM
New Aftermarket lca's 220$$$$ CA executivekoala Brakes, Suspension, Chassis 4 05-16-2015 07:34 PM
WTB aftermarket Oil cap BlackyRose Want-To-Buy Requests 2 10-16-2013 11:14 AM
Aftermarket Amp Kit for FRS kombatlion Electronics | Audio | NAV | Infotainment 7 11-06-2012 02:03 PM
Aftermarket HU and XM beefalo Electronics | Audio | NAV | Infotainment 0 06-30-2012 01:31 AM
