Old 05-22-2016, 09:38 AM   #1
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Round 1 of the Toyota 86 one make racing series full video.
Thought you guys might enjoy this. This weekend was the first round and three races of the new Australian one make Toyota 86 Racing Series.
The round was held at Winton Raceway a few hours outside of Melbourne in Victoria, Australia.
A lot of cars and a lot of contact action.
These cars are essentially stock except for AP brakes, MCA Coilovers, a roll cage, full exhaust systems and Motec engine management systems.
For info on the car specs see here. http://www.toyota.com.au/assets/pdf/...egulations.pdf
ROUND 1 RACE 1
[ame="https://www.youtube.com/watch?v=4VgirCfD3I0"]https://www.youtube.com/watch?v=4VgirCfD3I0[/ame]
ROUND 1 RACE 2 1/2
[ame="https://www.youtube.com/watch?v=0DFIIXa74QI"]https://www.youtube.com/watch?v=0DFIIXa74QI[/ame]
ROUND 1 RACE 2 2/2
[ame="https://www.youtube.com/watch?v=W2is_fTmUz0"]https://www.youtube.com/watch?v=W2is_fTmUz0[/ame]
ROUND 1 RACE 3
[ame="https://www.youtube.com/watch?v=gWxTR39sA4k"]https://www.youtube.com/watch?v=gWxTR39sA4k[/ame]
Wise is offline   Reply With Quote
The Following 17 Users Say Thank You to Wise For This Useful Post:
86geek (05-22-2016), ajaxthebetter (05-22-2016), BatStig (05-22-2016), bcj (05-22-2016), DAEMANO (05-22-2016), FLYFISHR (05-22-2016), gramicci101 (05-22-2016), hmong337 (05-22-2016), humfrz (05-22-2016), JD001 (05-22-2016), kch (05-23-2016), Lonewolf (05-22-2016), Mr.Impreza (05-22-2016), swarb (05-22-2016), TEWwild (05-22-2016), Who8myrice (05-22-2016), WryGuy (06-04-2016)
Old 05-22-2016, 11:33 AM   #2
Northwest86
Drives: Velocity Orange 86 GT
An excellent series. A little bit of a shame they spent so much time concentrating on the pros but with so many cars who they dont know I can see why the Pros and the sons will get the most attention.
Northwest86 is offline   Reply With Quote
Old 05-22-2016, 11:37 AM   #3
Lonewolf
Lonewolf's Avatar
Drives: Moped
Thanks for the clips!
Old 05-22-2016, 04:37 PM   #4
humfrz
WOW! what a race and I didn't even have to leave my easy chair ......
humfrz
Old 05-22-2016, 04:46 PM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
So many cars, not enough laps.. much better than the BTCC in the UK.
Old 05-22-2016, 04:54 PM   #6
PNW FRS
PNW FRS's Avatar
Love the "specs"
Some of the specs that caught my eye...
S13.1 Tyre Regulations
(a) Only the control tyres listed below are permitted for use in the Series:
 Front and Rear: Dunlop Direzza 225/40R18 DUNLOP DZ2* 86 Spec
S14 FUEL
(a) Only the control fuel may be used from the commencement of practice onwards at a Meeting.
(b) For the duration of a Meeting, competitors must only use the specified control fuel supplied by the official fuel supplier as detailed below
S15 AUTOMOBILE MARKINGS
(c) Each competitor is not permitted to display the signage of an automobile manufacturer other than TOYOTA on an automobile without the prior written approval of the CA.
T6 ENGINE
T6.1 General
(a) Each engine and its components must remain identical in all respects to the original production engine, as supplied by the automobile manufacturer and modified as detailed in the relevant CAMS Recognition Document
T6.2 Electronic Engine Control Unit (ECU)
(a) With the exception of any software or firmware owned and installed exclusively by the CM, the ECU and all associated wiring must remain unmodified unless otherwise approved in writing by the TC or TM.
(b) All sensor inputs and outputs to the ECU must be connected and operational at all times.
(c) At any time during a Meeting the TM may remove the ECU from an automobile and replace it with an ECU owned by the CM. This is not subject to protest or appeal.
T8.3 Ground Clearance
(a) The minimum ride height of the ready-to-drive automobile (with the driver in the automobile and tyres at 1.8bar +/- 0.1 bar air pressure) must not be less than the specified dimension, as measured at the specified measuring points, at any time during the Meeting.
(b) At all times during a Meeting, the ride height must comply with the following:
- The front chassis must be a minimum of 140mm
- The rear chassis must be a minimum of 280mm.
T8.4 Camber
(a) The maximum negative camber permitted for each front wheel is 4° degrees.
(b) The maximum negative camber permitted for each rear wheel is 2.2° degrees.
T15 WEIGHT
(a) Each automobile must achieve a minimum weight of 1200kg (2645.547 lbs) This weight shall consist of the automobile only, inclusive of all liquids in any OEM tanks which are part of the automobile.
Kind of reminds me of the old IROC series... racing identically (for the most part) cars cars so that the race is more about the driver than the rig...
Would be great to see this expand to the States.
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
The Following 2 Users Say Thank You to PNW FRS For This Useful Post:
DAEMANO (05-22-2016), WryGuy (06-04-2016)
Do you guys know about the "Touge" video series Toyota produced? bobaab FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 04-15-2018 10:01 PM
Feel the Power of Hybrid: 2015 Toyota Racing Launch Video JPxM0Dz Off-Topic Lounge [WARNING: NO POLITICS] 4 03-27-2015 03:51 PM
CSCS Round 3 Video mikal7 BRZ Photos, Videos, Wallpapers, Gallery Forum 0 08-15-2013 01:54 PM
Sweet New Toyota Racing Video apexr7 Off-Topic Lounge [WARNING: NO POLITICS] 0 09-28-2012 05:52 PM
