Old 05-20-2016, 06:25 PM   #1
ChrisWinnn
Drives: Frs
Shift Knob not flushed
Hey guys just got a flossy shift knob and it doesn't sit all the way down and there an annoying white strip. Any way I could solve this?
ChrisWinnn is offline   Reply With Quote
Old 05-20-2016, 07:02 PM   #2
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
I think I just kept screwing
That being said, did you use any of the bolts that came with your knob? I did not use any that came with mine.
Subaru STI :
Old 05-20-2016, 07:11 PM   #3
nunonuna
nunonuna's Avatar
There might be small hex nut/bolt inside of your knob. If so, screw that nut all the way in. If there is no nut in side of your knob, I dont know.
Also, you can use that small nut/bolt to adjust stop point so the gear pattern or logo is aligned well.
nunonuna is offline   Reply With Quote
Old 05-20-2016, 08:17 PM   #4
ChrisWinnn
Drives: Frs
Yeah I screwed the nut all the way down and the knob but when I do it's still misaligned so I'm still stuck. I was thinking of buying the Raceseng reverse lockout to cover the white strip but I don't want to drop 80+$ just to cover it ....
Old 05-20-2016, 10:18 PM   #5
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
I have a red Raceseng reverse lock that I'd be willing to sell for 50$. Maybe 4 months old in near flawless condition.
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
Old 05-20-2016, 10:45 PM   #6
Kimsey47
Kimsey47's Avatar
Not going to lie... I literally used a few small bits of toilet paper stuffed into mine to get it aligned correctly! It did end up covering a lot more of the white that you're showing. I think I can barely see it when trying. I'll try snap a pic tomorrow and if you haven't heard from me by noon hit me up as a reminder to snap a shot of mine.
EDIT: Found link I'd posted in the past of car w/Flossy (Sorry for the big pics). Let me know if that view isn't good enough and I'll get more like at the angle you're showing etc.
LINK: http://www.ft86club.com/forums/showp...&postcount=137
Subaru STI :
Old 05-21-2016, 03:27 AM   #7
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Pretty sure the nut is not the correct type if it's all the way down and the knob is still sitting so high up.
You need a "jam nut" - it is half the height of a regular nut:
https://www.belmetric.com/zinc-plain...dkccef7dhn44u1
If that's the nut you have, then there may be something wrong with the threads in your shift knob, it may need to be re-tapped / chased to clean it out.
aegisdrgn is offline   Reply With Quote
Old 05-21-2016, 03:42 AM   #8
pauletello
pauletello's Avatar
I had this issue too, but then I got this:
http://www.infocusclothing.com/interchangeable-bases/
pauletello is offline   Reply With Quote
Old 05-21-2016, 08:40 PM   #9
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
You're gonna need a reverse lockout adapter. My Blox knob came with it but since it sat out in the sun it turned from black to a copper/brownish color.
Here's what I'm referring to.
Clueless
YamahaR86 is offline   Reply With Quote
Old 05-21-2016, 08:45 PM   #10
aegisdrgn
aegisdrgn's Avatar
If he has a Flossy shorty heavyweight knob, it should screw all the way down, hiding the white part of the reverse lockout. He shouldn't need an adapter.
Old 05-21-2016, 10:38 PM   #11
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Off topic, but it's good to see someone still hanging an American flag outside their house.
MS, CSCS, TSAC-F, CPT
Old 05-22-2016, 09:53 AM   #12
stevesnj
stevesnj's Avatar
I ran into the same issue when I put on my knob, what I did was just get a stainless nut lockdown and trimmed the plastic slider just below the top of the lockout top. The look came out great and I don't have to get a custom lockout.
My 2016 Build thread
Old 01-31-2018, 02:55 PM   #13
Lightning McBRZ
did you have trouble getting your infocus base down? They said they sent me the right thread pattern but I can't seem to get mine on
Lightning McBRZ is offline   Reply With Quote
Old 01-31-2018, 04:12 PM   #14
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Sounds like a bunch of you got the wrong knob.
Thinking you guys got a knob for a car that doesn't have the reverse lockout.
SOLD: carbing shift knob infocus shift boot digital camo toby714 Interior Parts (Incl. Lighting) 6 07-02-2015 09:33 PM
FS: WeatherTech Mats/Shift Knob/Shift Boot/Sunshade (WI) wgnzlz Interior Parts (Incl. Lighting) 8 06-09-2014 09:36 PM
FS Raceseng 86 AT Shift Knob and Cusco Red SPin Turn Knob Unidentified Interior Parts (Incl. Lighting) 2 01-06-2014 09:55 PM
Flushed Taillights R4PT0R-X Cosmetic Modification (Interior/Exterior/Lighting) 31 09-23-2013 10:16 PM
