Drives: 2014 BRZ limited (DGM)
OEM subwoofer... should I sell it or replace the speaker/amp?
I have a '14 brz limited that I purchased about a year ago and it came with the factory sub/amp combo that fits nicely and adds a touch of bass, just not enough for my taste. So I'm wondering if I should sell it and buy a more powerful sub and amp and then glass my own box or if I should sacrifice the speaker and replace it with a more powerful one?
Sent from my XT1254 using Tapatalk |
Off Topic
The problem is not the speaker; the problem is the amplifier. It's only a 100 watt amp, and it's integrated into the box. It doesn't matter what speaker you put in there; it'll still be driven by the 100 watt amp. If you find a speaker that's 6dB more efficient than the current one then it'll sound twice as loud, but that'll be difficult given the limited amount of airspace you have to work with.
If you want a molded box, there are several to choose from. Integrity Concepts makes enclosures for 10's and 8's on either the driver's or passenger's side. I believe they're a forum vendor. Obviously, you'll need to provide a sub and amp. http://www.integrityconcepts.net/sci...-products.html OEM Audio+ makes a very nice 8' sub, but it's integrated with their full sound system. Which is also very nice. They're also a forum vendor. http://oemaudioplus.com/subaru/brz-2/ JL has a loaded enclosure, made with typical JL quality and prices. http://www.crutchfield.com/p_1369456...tealthbox.html MTX makes both a loaded/powered and unloaded enclosure. https://www.mtx.com/sfrs13fb10a-tn-s...ofer-enclosure https://www.mtx.com/sfrs13fb10u-scio...ofer-enclosure There are probably a few others out there as well. |
| Have to replace entire assembly to replace fuel filter? | tobkin | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 08-04-2017 02:26 PM |
| VIDEO GUIDE - Build your own door speaker mounts using the factory speaker shells. | The Sentinel | DIY (Do-It-Yourself) Guides | 3 | 01-28-2016 05:39 PM |
| To replace rims or not replace? | unlimited86 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 23 | 09-21-2015 12:12 PM |
| Better Mic to replace OEM Mic in BRZ / FRS ??? | Zgrinch | Electronics | Audio | NAV | Infotainment | 42 | 02-06-2015 01:19 AM |
| You have to replace your Toyobaru, what would you buy? | strat61caster | Other Vehicles & General Automotive Discussions | 50 | 10-01-2014 07:12 PM |
