Old 05-17-2016, 11:37 PM   #1
makesdrivingfunagain
Center of Gravity Difference Manual/AT
Hi fellow enthusiast,
Since the automatic weigh nearly 50lbs more does the Auto have a different center of gravity? Newbie non-engineer question I know.
http://www.motortrend.com/news/2013-...s-first-drive/
makesdrivingfunagain is offline   Reply With Quote
Old 05-18-2016, 12:15 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
As most probably all the extra weight will be in transmission/gearbox at bottom of car, overall CG of car might be even lower on heavier AT. Unless they started to mount gearbox on the roof of car
Old 05-18-2016, 06:16 AM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I don'tthink there would be enough of a difference to measure. 50lbs over a 2800 lb object isn't much and since the COG of the car is 18.1"- that's about the height of the center of the tranny.
Old 05-18-2016, 02:02 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The weight distribution may be shifted depending on how the transmission weight is distributed. But otherwise there's going to be zero difference you can feel...
The Following User Says Thank You to mav1178 For This Useful Post:
clutch77 (05-18-2016)
Old 05-19-2016, 08:35 AM   #5
Ashikabi
Ashikabi's Avatar
It will be lower since the transmission is low in the car. That extra 50lbs will be unnoticeable COG wise. Should trade up to a manual for weight savings
Old 05-19-2016, 08:49 AM   #6
As others have said, it is minimal, and most likely would lower it because the weight is in the transmission. It is only minimal, however, because the weight is already near the CG. If the same 50lbs was put further out on the "arm" (say in the trunk) it could significantly move the CG rearward.
Basically, its determined by the weight distribution at the wheels. Here's a good diagram, although this does not take into account the height of CG.
Old 05-19-2016, 08:53 AM   #7
Ashikabi
Ashikabi's Avatar
I thought COG was in a verticle plane, not front to back
Old 05-19-2016, 12:24 PM   #8
It's both. The vertical CG would exist at a right angle to the horizontal CG. They impact one another. The vertical is a little more complicated to determine. Here is an example.
Shankenstein (05-20-2016)
Old 05-19-2016, 12:29 PM   #9
Ashikabi
Ashikabi's Avatar
You lost me... either way the transmission is low and in the middle front to back so it really doesn't matter much
Old 05-19-2016, 12:33 PM   #10
That was my point, it would have minimal impact because it is already pretty much at the horizontal CG, and would only act to lower the vertical CG.
My point was if you put the same 50lb weight in the trunk of the car, it would have a much greater impact, moving the CG towards the rear and up.
This is why a 200lb passenger/driver in the car has very little impact on CG as they are very close to it, but put that same 200lbs elsewhere and it has an impact.
Old 05-19-2016, 12:43 PM   #11
gramicci101
Off Topic
You don't have a cool Army-proof picture for determining vertical CG?
The Following User Says Thank You to gramicci101 For This Useful Post:
Dadhawk (05-19-2016)
Old 05-19-2016, 02:09 PM   #12
Sadly no. Apparently on wheeled vehicles the military is only concerned with center of balance (the horizontal component). They do have it for aircraft though where true CG is more important than the center of balance.
Technically, in most applications (if I recall correctly) the horizontal component is more important than the true center of mass (both of them together).
Old 05-19-2016, 02:15 PM   #13
gramicci101
Off Topic
Yeah, horizontal CG is necessary for shipping. Especially for air movement, so you can make sure your load plan is balanced and your plane isn't too nose or tail heavy. Vertical CG, not so much.
Old 05-19-2016, 02:38 PM   #14
Yep, in aircraft a CG moved just slightly too far forward means you'll never take off, and too far back means you won't survive the landing.
Center of Gravity Location RMP Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 04-10-2015 03:34 PM
difference in exhaust for automatic vs manual? agoodcar Engine, Exhaust, Transmission 4 10-27-2012 03:19 PM
weight difference between auto and manual??? sofrsnsokleen Scion FR-S / Toyota 86 GT86 General Forum 1 08-22-2012 11:40 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
Power difference between automatic and manual? Eurasianman Engine, Exhaust, Transmission 5 05-02-2012 04:14 PM
