Old 05-15-2016, 11:54 AM   #1
SimplyIcy
Drives: 2015 K1X_Halo FR-S
P0068 code on MAP turbo
So I just had DW injectors installed and was running FIC before with problems (found out they where faulty) but regardless I was driving today and upon coming off of the highway my car popped the P0068 code and went into limp mode. I can no longer pedal past half throttle without it dying down and defaulting to 2,000 RPMs. This is a new tune for a 3 bar and 700cc injectors. Do you think the scaling could be off? Or did one of the tubes pop off and how can I check to see if I tube did pop off.
SimplyIcy is offline   Reply With Quote
Old 05-15-2016, 05:22 PM   #2
FRS Justin
Drives: 2013 Asphalt FRS
A tube popping off usually results in a high idle... Try reloading map if it still does it go back to original map and try it.. MONITOR AFR and KNOCK CORRECTION if you try old map.. If it does not change look for a open or short to ground on the MAP circuit.
Basically this code is set with throttle open above 10% and and a difference between MAF and MAP correlation.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
steve99 (05-16-2016)
Old 05-15-2016, 07:52 PM   #3
steve99
as above what justin said and also get your tuner to check the MAP sensor settings for whatever MAP sensor is installed.
they may have to also adjust the min/max expected voltage levels
P0068 is map sensor out of bounds or correlation error.
for example a omni 3 bar map sensor (your may be different and scalings can be in metric or imperial
3 Bar OMNI MAP sensor ECUTEK scaling in BAR
Omni 3 Bar MAP Sensor (Metric in Bar)
0.617 - MULTIPLIER
0.03 - OFFSET
scaling limits 0 - 4.75v
Manifold Pressure Sensor Limits - (CEL still comes on )
High Input CEL Above - 5.00v
Low Input CEL Below - 0.00v
or sometimes they just
Disable CEL P0103 and P0068 but safer to leave them in
FRS Justin (05-16-2016)
Old 05-16-2016, 08:32 AM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yup, P0068/0069 CEL limits need adjusting.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
FRS Justin (05-16-2016), steve99 (05-16-2016)
Old 09-27-2016, 03:55 PM   #5
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Can someone with a good running car, unplug the map sensor and measure each wire voltage so i can check to see if my wires are good. I need to find out if my map sensor is bad or if i have a break in the wire.
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 09-27-2016, 04:07 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
What are you seeing if you log the sensor voltage?
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-27-2016, 04:50 PM   #7
sosick
fastest frs in sbg
sosick's Avatar
Randomly maxing out. If i tap it lightly with finger it maxes out. If i wiggle wires it maxes out. Idk wtf is going on
2014 firestorm frs
Old 08-16-2018, 10:39 AM   #8
ShawnP19
ShawnP19's Avatar
Drives: 2016 Series.HyperBlue BRZ
Long shot but did you figure this out? I'm dealing with something similar, and starting to suspect wiring instead of sensor.
ShawnP19 is offline   Reply With Quote
Old 01-12-2019, 04:14 PM   #9
sosick
fastest frs in sbg
sosick's Avatar
map sensor was shot. changed it and car ran like no ones business.
2014 firestorm frs
Old 06-17-2019, 10:28 PM   #10
ltown
Drives: 2013
0.617 - MULTIPLIER
0.03 - OFFSET
so this is common? cause im on my base map tune for a brand new forced induction kit and this code came up after 10m of driving. is this something a tuner adjusts? obviously im just on the base map and theres more room to tweek but should i let the tuner know that it came on?
ltown is offline   Reply With Quote
Old 06-17-2019, 11:27 PM   #11
steve99
Yeah when you go fi you tend to use more of the sensor range so you often need to extend the cel trip points. Im assuming the sensor is ok and scaked correctly. You should see 1 bar or 14psi with ignition on and engine stopped, that atmospheric pressure
Old 06-18-2019, 01:52 PM   #12
ltown
Drives: 2013
in the base map instructions i was told that i should see 0.0 boost at key on engine stopped? and to email them if it was more then .3 off. its a BAR 3 that he scaled if for cause i put it in my mod list that i sent him. when i checked it today its at 0.15 boost engine off. (this is on the openflash system)
Old 06-18-2019, 05:53 PM   #13
steve99
Oft boost parameter is reliative to atmostpheric so yes it should read 0 or close to zero, from memory its in psi so a reading of 0.15 psi is fine atmospheric pressure varies a little with altitude.
It more likely the cel limit setting, the scaling seems ok
Old 06-18-2019, 08:46 PM   #14
ltown
Drives: 2013
ahhh ok, kinda what i was thinking. thank you. ill include that the light came on in my next revision map request.
Another CEL code whitefrs Forced Induction 20 11-27-2019 11:27 AM
Lean Code and 02 Code diagnostics. Kiske Engine, Exhaust, Transmission 12 04-28-2016 10:19 PM
P0301 code -turbo frs mario17623 Forced Induction 25 09-14-2015 06:38 PM
P0068 code on tuned vortech help please Frs32907 Forced Induction 23 04-09-2014 08:19 PM
CEL code ChandlerSwyng Issues | Warranty | Recalls / TSB 2 04-08-2014 01:27 AM
