Old 05-12-2016, 07:22 PM   #1
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
FS: GFB Pulley Set
$100 OBO
Paypal only, shipped anywhere in the continental US.
GFB lightweight pulley kits are made from aircraft-grade 6061-T6 aluminum and offer faster acceleration through significant weight reduction on the crankshaft. The effect is similar to a lighter flywheel, and the car feels more lively and willing to rev.
This kit includes the crank and water pump pulleys.
Stock Crank Pulley : 4.89lb
GFB Crank Pulley : .75lb
Stock Water Pump Pulley : 1lb
GFB Water Pump Pulley : .53lb
That is almost 5lbs of rotational mass lost.
Just the crank pulley and water pump pulley as pictured. Nothing wrong with them, cleaning out the garage. I will ship in the original box. Seen the 3 piece set going for around $300. It's missing the alternator pulley which really isn't much of a weight savings.
industrial is offline   Reply With Quote
Old 05-12-2016, 07:30 PM   #2
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
ATI Super Damper
sold!
ATI Performance Products, Inc. is proud to introduce its Super Damper (Part # 918482) for the Subaru BRZ and Scion FR-S 2.0L boxer engine for street and high performance racing applications. The new aluminum-shell, steel-hub damper features a 10% underdriven belt drive that works with the OEM belt set-up. It's a direct fit replacement for the stock OEM unit and is better capable of handling a wider variety of driving habits that owners will put their new cars through. OEM dampers are optimally tuned to a narrow band of perceived normal driving conditions and do not perform well outside of those limits. The ATI Super Damper can handle any engine speeds and driving conditions that get thrown at it to better protect your engine. ATI Super Dampers provide balanced dampening of torsional crankshaft vibrations through all RPM ranges and exceed SFI 18.1 Safety Certification for competition use.
Like new in the original box. Never really got around to installing it. I will ship it in the original box. The cheapest price I can find online is $448 for the right part number (
918482).
Old 05-16-2016, 10:19 AM   #3
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Bump!
Old 05-18-2016, 03:29 AM   #4
HAWAIICALIVEGAZ
HAWAIICALIVEGAZ's Avatar
Drives: HONDA, TOYOTA
Pm'd ya
Sent from my SM-G935V using Tapatalk
HAWAIICALIVEGAZ is offline   Reply With Quote
Old 05-20-2016, 06:04 PM   #5
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
bump price drop on the GFB!
Old 05-23-2016, 03:42 PM   #6
Kckc1
Drives: White brz series blue
How would you expect this to affect a supercharged setup?
Kckc1 is offline   Reply With Quote
Old 05-24-2016, 11:31 AM   #7
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I don't think either pulley would work with a supercharger since most kits either replace or are designed to interface directly with the stock pulley.
Old 06-10-2016, 10:19 AM   #8
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Price drop, bump!
Old 06-12-2016, 08:00 PM   #9
MattHoffman
Drives: BRZ Limited
If you are talking about talking about the gfb set it shouldn't be an issue at all. I have the perrin pulleys with my Vortech
MattHoffman is offline   Reply With Quote
Old 06-26-2016, 07:00 AM   #10
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I..... Oh super damper is sold... >_> free bump then.
Raceseng s2 pulley kit cjm86 Transmission and Driveline 6 06-30-2015 11:47 PM
3pc Pulley kit kincaid0890 Engine, Exhaust, Transmission 0 08-20-2014 08:08 AM
Perrin crank pulley / Beatrush alternator pulley Krimlin Engine, Exhaust, Bolt-Ons 7 08-26-2013 10:12 AM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
